Forum: FPGA, VHDL & Verilog Design verification in FPGA
von Deepika A. (deepika)
Hi all,
I am working on FPGA and I am using chipscope to verify my designs. In
this case I will set the input test patterns and I will verify the
corresponding output. But the problem with this method is that, it is
time consuming.
So, I am searching for techniques to automate the verification in FPGA.
Can you please tell me the options available to automate the
verification and their pros and cons.
Thanks
> to automate the verification and their pros and cons.
Nivce try, but isn't that YOUR homework?
von P. K. (pek)
Instead of comparing the chipscope results outside, you can do that
directly inside the FPGA having two different possibilities:
- Assertion based simulation (not synthesizable, but helps
  find errors already during simulation)
- BIST (built-in self test). You gather the data as before,
  instead of storing in RAM and read to the PC, you have
  your comparing engine directly within the FPGA. The BIST
  will tell you go/no-go and even may come up with some
  diagnostics, if you do it well...
von Strubi (Guest)
if Co-Simulation is not an option, meaning, you are forced to use HW,
you might be better off hacking your own chipscope with the more or less
well documented features of the JTAG primitives (which are a pain on
some older Xilinx-FPGAs). However, having a proper JTAG testing front
end (i.e. fast adapter and boundary scan driver routines) can range from
a cheap FTDI solution up to a serious investment - depends on how many
test vectors you need to play back on your design. Maybe you have to
elaborate on what you are targetting at.
Cheers,
- Strubi
