Forum: FPGA, VHDL & Verilog Common Counter FSM Reset
Author: bumo (Guest)
Hello,
I want to use a common counter for several states within a FSM. As long
as there is a state inbetween which does not use the counter it can be
reset in time, but if the following state uses the counter, the
comparision logic in this state samples the counter value from the
previous state before it is reset.
Is there some other kind of design pattern to deal with this problem?
Thank you in advance.
: Moved by Moderator
Your problem is namend "latency".
And it can simply be solved: just manipulate the counter value in a
manner that it gets a useful value when leaving the previous state.
BTW:
I moved your English question from the German to the English forum.
If you want to post in the German forum pls. write German...
Maybe i don't get it, but "manipulating the counter" for the next state
cannot work when it is clocked. Let's consider the following example:
-- register
process (clk, rst) is
begin
  if rst = '0' then
  elsif rising_edge(clk) then
    state <= next_state;
    cnt <= next_cnt;
  end if;
end process;
-- fsm
process (..., cnt) is
begin
case state is
  when current =>
    if cnt > limit then
      next_state <= next;
      next_cnt <= (others => '0');
    else
      next_cnt <= cnt + 1;
    end if;
  when next =>
    if cnt > smaller_limit then
When the condition cnt > limit is reached, next_cnt will be reset, but
since the next state will be set also, the condition cnt > smaller_limit
is true for the first clk cycle...
> BTW:
sorry for that.
: Edited by Moderator
never mind, my own twisted logic, fsm is not clocked...
thx
How did you figure that out? By simulation?
Indeed both of them cn and state result in  a similar hardware: more
or less a simple counter consisting of flipflops. And if state gets
the new value, then at the very same time cnt gets its new value also.
> the condition cnt > smaller_limit is true for the first clk cycle...
It may only be "true" for a few picoseconds after the next clock edge:
after the clock edge the flipflops in the FPGA get new output values and
the whole FPGA is busy and "glitchy" until the logic has reached its
next stable values and has calculated the next counter value. And this
stable values results are the next values for cnt and the next values
for state.
A short while later the following clock edge transferres this values to
the flipflops output and the show starts again.
With the two-process style you have spilt off the flipflops and the
combinatorial logic explicitly. Now think about the whole thing again,
but simply assume, the clock comes ony each minute or hour. Then there
plenty of time for the logic to stabilize.
The whole thing is called "synchronous design".
EDIT:
So, I was a little bit too late... ;-)
  • [vhdl]VHDL code[/vhdl]
