Forum: FPGA, VHDL & Verilog Zooming, Brightness, & Contrast Program ov7670 With Spartan 6
von Freddy S. (Company: Teknok) (freddysilaban)
Hello My Friend...
there anything can help me , I have trouble in the program to create an
auto brightness and auto contrast from vhdl program . as well as the
zoom in vhdl.
i am use module FPGA Nesyx 3 Spartan 6...
I use the reference program at :
http://hamsterworks.co.nz/mediawiki/index.php/Zedboard_OV7670
Regard's
Freddy
Freddy S. wrote:
> I use the reference program at : ...
And now show what you have added and tell us whats the problem with
that. Ask a question about a particular problem. But no one here
intends to do your homework completely.
A few hints:
1) Brightness
calculate the mean value of the incoming data. If this mean value is
different from the desired "auto brightness level", then multiply the
incoming data with a scaling factor. You can get the scaling factor out
of the calculation "desired brightness / incoming brightness". With a
little bit thinking no float value is neede here...
2) Contrast
Look for the minimum and the maximum value in the incoming data. If the
difference between them (thats the contrast) is too less or to much then
multiply the incoming data with a scaling factor. Here the scaling
factor is likewise "desired contrast / incoming contrast". Afterwards
you must scale the brightness, because a change in contrast results in a
change in brightness.
Look for saturation in those to stages!
3) Scaling
Is much more tricky, because you must store the image in memory. And
then for "stretching" you must calculate a new image with interpolated
pixels or for "compressing" you must skip some pixels and interleave
their values to a new one. In both stages you must weight the "distance"
of the new pixels to the original pixels.
Dear My Friend
apart from the camera ov7670 , what type of camera supports  FPGA
Spartan 6  Nesyx 3? More easily configured ...
i distress configuration  brightness, contrast , and zooming using
ov767...
Regard's
Freddy
von Ruckzuck Fresse Dick, Mr. (Guest)
von fpga pongo (Guest)
my full respect for those in here who still have the patience to answer
such threads which are invoked once by a user who will never return
you can order this as a set of cores:
- continous zoom
- auto gain
- auto offset
- auto brighness
- auto whitening
- auto contrast
- auto saturation
... all for SD and DH video, various formats.
prices negotible
> - continous zoom
> - auto gain
> - auto offset
> - auto brighness
> - auto whitening
> - auto contrast
> - auto saturation
> prices negotible
Dear FPGA pongo
my research on auto brightness and auto contrast using Spartan 6 FPGA
Nexys 3, until now I have not been successful.
what price for auto brightness and auto contrast to completion?
Can you email in : exasilaban@gmail.com
regard's
Freddy
