Forum: µC & Digital Electronics How to connect Raspberry Pi to a much smaller connector type
von David (Guest)
Dear Community,
I have to apologize if this is not the right section for this question,
but I didn't know which topic would be the right one.
My Task is the following. I have a Raspberry Pi and want to connect the
GPIO Pins of the Raspberry with a connector of a Laser (for RS232
communication). But the connector of the laser is much smaller. In the
documentation of the laser the connector is listed as:
"User’s connector on transponder board: Samtec P/N CLM-107-02-H-D-K-TR
or equivalent. This connector is equivalent to CLM 107-2-X-D with
additional plating for GR1217 metallurgical compliance."
What I am looking for is some intermediate connector/adapter to somehow
allow me to use wires (like this:
https://www.amazon.de/Breadboard-Steckbr%C3%BCcken-Drahtbr%C3%BCcken-Stecker-Jumper/dp/B00IRYUU8S/ref=sr_1_1?ie=UTF8&qid=1473337019&sr=8-1&keywords=male+jumper+wire)
to connect the Raspberry with the Laser. But wires of this size won't
fit into the small connector. At my local electronics store (Conrad)
they didn't have a connector small enough to fit. I don't know the right
terms to look for such a part, so I hope someone could help me or at
least tell me the name of the part I might be looking for.
Thanks!
David
von Schlumpf (Guest)
Why don´t you use a soldering iron and make your own adaptor?
von Georg (Guest)
That will be impossible, because these Wires will never fit into such a
small connector. A practical approach is to make a cable with a
connector for Pi I/O at one end (female, not male!!) and a samtec
connector at the other end.
What he needs is a cable. If he uses an adapter, the cable is still
necessary.
Georg
von ./. (Guest)
Have a look at Samtecs parametric search and apply for
"Mating Connector" and search for Your connector type.
With the mating connector it should be easily possible
to construct a matching adapter to whatever You like...
German Sprichwort:
"Adapter wachsen nicht an Bäumen."
