Forum: FPGA, VHDL & Verilog Signal debouncing for high speed and accuracy
von Chris C. (customchris)
Hi everyone, just had 2 ideas and wanted to get some opinions on them.
I have a signal that I am wanting to debounce by code vs discrete
components. Ive been running an example code that generates a interrupt,
then counts up to a set number of bits, then samples the signal and
outputs what it sampled, this is good for a basic push button, but I
have a very timing critical application that will need some
experimenting with and therefor having this done in code would be
faster. My plan is to create a type of capacitor in vhdl, a simple count
up by "x" when high, and count down by "y" when low, this will allow me
to create "full" and "empty" thresholds on the fly and hopefully less
glitches or late signal changes than desired.
The second version would check to see if the prior state was held to
certain amount of time to decide if there was a glitch or intended state
change. the signal sampled will have a high time varying between 1.5ms
to 5ms and the low between 4ms to 200ms. Here's a quick example. Let me
know what you think please.
 counter_set <= flipflops(0) xor flipflops(1);
 -- single clk wide pulse interrupt whenever signal changes states.
  PROCESS(clk)
  BEGIN
    IF rising_edge(clk) THEN
      flipflops(0) <= SIGNAL;
      flipflops(1) <= flipflops(0);
      If(counter_set = '1') THEN
       if offtime > 50000 and ontime <2500  then
        if flipflops(1) = '1' then
            SIGNAL_OUT <= 1;
            ontime <= 0;
            offtime <= 0;
      ELSIF ontime > 50000 and offtime <2500 THEN
         if flipflops(1) = '0' then
            SIGNAL_OUT <= 0;
            offtime <= 0;
            ontime <= 0;
      ELSE
       null;
             END IF; END IF ;END IF; END IF; END IF;
              ontime <= ontime + 1;
               else
                offtime <= offtime + '1';
                  end if;
      END IF; END PROCESS;
: Edited by User
Chris C. wrote:
> Let me know what you think please.
a) Pls use the [vhdl] tags
b) Use proper identation to get the code readable
c) There's on "end if" too uch in the code... :-/
Usually only mechanical switches must be debounced because to the
bouncing of a mechanical contact. Here it sounds more like you want to
filter a signal. So where does your signal come from? Why is it noisy?
For simply debouncing a switch signal have a look there (its German):
http://www.lothar-miller.de/s9y/categories/5-Entprellung
The signal is pulled up on the fpga side with a 220 ohm resistor and is
routed to another circuit about 3 feet away, inside this second circuit
is a switching transistor, a malfunction checking transistor and a
capacitor, this system is also in a very noisy environment around a/c
voltage and spark discharge, occasionally there is some noise when
switching on and less when switching off, my current built prototype
does not have the ability to add discrete components to solve this
problem, so until my next run of boards and to continue development, I'm
stuck with filtering in code. The signal delay cannot be more than 1uS,
which is where the problem lies, the bounce typically happen a few times
within the first 50uS of signal transition.
Chris C. wrote:
> The signal delay cannot be more than 1uS, which is where the problem
> lies, the bounce typically happen a few times within the first 50uS of
> signal transition.
Is the bouncing easy to be recognized on a scope?
Is each "switch cycle" longer than 50us?
BTW: uS means "micro Siemens" and thats the reciprocal of MΩ
Sorry about the mistakes, I wrote it out as It came to me on here, I'll
probably give this a shot, seems like it may be the most accurate way,
just would like to hear what anyone thinks of this system, pros and
cons.
