Forum: µC & Digital Electronics Does Raspberry cause magnetic disturbances HMC5883L
Author: k-str (Guest)
Hello to all,
I'm new here und I have some problems to use a HMC5883L as a compass.
During maeasuerements I see that the raspberry interferes the magnetic
field.
Has sombody experience in this problem? How far should th raspberry be
away from the HMC5883L? And how can I avoid this poblem?
Thanks in advance.
Kurt
Author: stefan us (Guest)
All electric devices cause magnetic interference. That's naturally.
Author: Kurt Struevy (k-str)
Hello stefan us
Thank you very much for this answer. But how can I avoid from this
problem?
How do you use this magnetometer as a compass if you have always
interferences from other devices?
Author: Hp M (Guest)
The coil of the DC-DC-converter propably emits dc and rf magnetic
fields.
The casing of the USB-connectors is made of steel and possily disturbs
the earth magnetich field.
Hello Hp M,
thanks for your answer,
What can I do in this case. What if I try to shield the RPI with some
like a cache of iron?
