Forum: FPGA, VHDL & Verilog UART on PCIe device is not working
von Viya V. (viyaaloth)
I am trying to monitor data from PCIe device (spartan 6 FPGA,
XC6SLX45T-3FGG484) in cutecom terminal on linux through UART.
I have written some data from root complex(linux in my case) to my PCIe
device( Spartan 6 FPFA) .Then I tried to monitor it in a serial terminal
via UART.
My FPGA is working in 100MHZ, I have changed DIVISOR accordingly for my
UART.
parameter Data_Bits = 8,
StopBits_tick = 16,
DIVISOR = 652,
DVSR_BIT = 10,
FIFO_Add_Bit = 4
But I am not getting any output in terminal
Any help would be appreciated.
Thanks & Regards,
Viya
Did you check you UART implementation stand alone (without the PCIe
bridge): only sending data to the UART and shwing it on LEDs and
sending data from the UART to the terminal?
Does your PCIe interface work?
Did you test it by sending data to LEDs and reading data from switches?
You must split up this singular huge problem in small problems. Then you
can verify and debug each small problem. If each component ist working
on its own, then you can connect them together...
von BigChip (Guest)
Hi Vija,
your problem description will enable nobody without crystal ball to help
you in your situation...
you wrote that you´ve got a PCIe device with an UART...
That's a rather complicate setup for an FPGA novice and I´m afraid you
are such one?
So here some question to help out with some informations for me and
others:
Could you simulate your design?
for later detailed help, language: VHDL,Verilog mixed?
Are the pin constraints set? I`m assuming that you used the PCIe
IP-Output as your starting point?
Could you be sure that you could do writes to your PCIe Node (Device
Memory Mapping, Access rights ?) - How do you handle this - Do you use
some code examples, using some helper APIs, wrote an driver plain by
your own?
Could you control some simple IO's (LED?) from your PCIe Node?
Could you use an Oscilloskop or Logicanalyzer for further analysis?
What kind of Hardware/Softwaresetup you are using ?
ISE Version?
Do you use an S6-Evalboard (known to work well) or might there be
physical/electrical problems?
What kind of translation you are using for connecting the FPGA towards
your Linux machine?`
UART-USB Chip/Translator etc...
Regards
BigChip
