Forum: FPGA, VHDL & Verilog how to read data from a ddr3 sdram?
von Hamid K. (Company: sharif) (hamidkavian)
Hi
I want to read data from a ddr3 sdram. I'm using vivado. my memory model
is
M471B2873FHS which is not mentioned in the "xilinx memory interface
generator".
what should I do?
thanks.
( I apologize for my bad English ).
von P. K. (pek)
You need a memory I/F within your FPGA. Unless you want to write it by
yourself, you can use the memory I/F IP (MIG) from the IP Catalog.
As an intro, see:
https://www.youtube.com/watch?v=wqaGBvQwyRc
von MIGgi Mouse (Guest)
Hamid K. wrote:
> Hi
> is
> generator".
> what should I do?
> thanks.
Hi Hamid,
Xilinx Memory Interface Generator simply initialize some Timing Values
by selecting a Memoy in the generation process.
You should be able to compare the data from the datasheet with Micron
Memories which should be avaiable and select the complementary part...
von video constructor (Guest)
I have a video board and need dual port access to a ddr sdram. I also
launched MIG to obtain a DDR3 Controller for my given design. I have
experience with DDR2 and DDR3 and am also familiar with the MIG.
Surprisingly the MIG does not offer a multi port option anymore for
current devices unlike it used to be before when I designed for spartan
3 e.g.
Anybody can help with this issue? in the Xilinx Forum it is discussed to
use a AXI based design or create a round robin controller myself.
anybody did this?
von BigChip (Guest)
Hallo video constructor,
your problem is very different to the original Thread Opener.
Please don't capture this thread but open your own.
Regards
BigChip
