Forum: FPGA, VHDL & Verilog export port from altera qsys to verilog toplevel wrapper or fpga IO pins
von anonymous dude (Guest)
with Altera QSys Tool, How to export a signal as an input or output pin
to the fpga?
looks like you need to create a "new component" with the signals you
want as your toplevel then bind a verilog model with required IO's to
the "new component"... then add this new component your "System
Contents" tab double click on the signals to export from the export
column (column 4)...
If anybody can describe this better or knows a better or different way,
then by all means write it here.
