Forum: FPGA, VHDL & Verilog bad synchronous description - ISE synthesis error
Author: Farzam (Guest)
Hello everybody. I have written the following VHDL code in ISE. In the
synthesis report I am having this error saying:
"line 100: Signal wea_sig cannot be synthesized, bad synchronous
description. The description style you are using to describe a
synchronous element (register, memory, etc.) is not supported in the
current software release."
I can't find the problem. I would be really thankful if someone could
help me here.
here is my code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity main_code is
    Port ( clk : in  STD_LOGIC;
          edone: out std_logic := '0'
end main_code;
architecture Behavioral of main_code is
signal dout_rom: STD_LOGIC_VECTOR(7 DOWNTO 0):=(others => '0');
signal address_rom: std_logic_vector(3 downto 0) :=(others => '0');
------------- component rom
COMPONENT rom_core
  PORT (
    clka : IN STD_LOGIC ;
    addra : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
    douta : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
signal wea_sig: STD_LOGIC_VECTOR(0 DOWNTO 0) :="0" ;
signal address_ram: std_logic_vector(3 downto 0) :=(others => '0');
signal din_ram: STD_LOGIC_VECTOR(7 DOWNTO 0):=(others => '0');
signal dout_ram: STD_LOGIC_VECTOR(7 DOWNTO 0):=(others => '0');
------------- component ram
COMPONENT ram
  PORT (
    clka : IN STD_LOGIC;
    wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
    dina : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
END COMPONENT;
signal counter: integer := 0;
signal counter_prime: integer := 0;
signal ero: std_logic_vector(7 Downto 0):=(others => '1');
begin
------port map rom
pm1 : rom_core
  PORT MAP (
    clka => clk,
    addra => address_rom,
    douta => dout_rom
------port map ram
pm2 : ram
  PORT MAP (
    clka => clk,
    wea => wea_sig,
    addra => address_ram,
    dina => din_ram,
    douta => dout_ram
(line 100)  process(clk)
begin
    if (counter_prime <9) then
          if(clk'event and clk='1') then
            counter <= counter + 1;
          wea_sig <= "0";
          din_ram <= ero;
       end if;
       if(clk'event and clk='0') then
           if(dout_rom < ero and counter/= 5)  then
                     ero <= dout_rom;
                end if;
           if(counter=1 or counter=3) then
               address_rom <= address_rom + 1;
           end if;
             if(counter=2) then
                address_rom <= address_rom + 3;
           end if;
           if(counter=4) then
              for i in 1 to 2 loop
                 if (counter_prime = i*3) then
                    address_ram <= address_ram + 2;
                        else
                            if(counter_prime /= 0 and i=1) then
                                address_ram <= address_ram + 1;
                    end if;
                        end if;
              end loop;
                  if (counter_prime = (3*i)-1) then
                    address_rom <= address_rom - 3;
                else
                    if (i=1) then
                       address_rom <= address_rom - 4;
                   end if;
                end if;
                    end loop;
            end if;
           if(counter=5) then
               wea_sig <= "1";
              counter_prime <= counter_prime + 1;  --end of each round
              --getting ready for the next round
                    counter <= 0;
              ero <= (others => '1');
           end if;
       end if;
    end if;
    if(counter_prime=9) then
      edone <= '1'; --erosion is done
    end if;
end process;
end Behavioral;
Farzam wrote:
> if (counter_prime <9) then                             if(clk'event and
> clk='1') then
Where did you find this very special way to describe a counter?
What does the manual of your synthesizer say to that?
A synchronous design usually starts with
if rising_edge(clk) then...
The design looks lousy due to the use of both clock edges. If I were
your teacher I would give it back for rework until only one and the same
clock edge is used throughout the whole design.
Thank you for the help. Actually I am new to synthesis and this code was
only supposed to simulate the algorithm at the first place which did
fine. It seems that I have to do more studies on synthesis.
If it is not a problem I would ask another question. Now I am trying to
write the datas from the ram to a text file. I have added the process
bellow to my code:
process(clk)
    file outfile: chartype;
    variable c: std_logic_vector(7 DOWNTO 0);
begin
    if(clk'event and clk='1' and counter_prime = 10) then
   end if;
    if(clk'event and clk='0' and counter_prime = 10 and counter < 16)
then
       file_open(outfile,"C:\write.txt",write_mode);
      c:= dout_ram;
      write(outfile, tochar(c));
   end if;
end process;
in which 'tochar' is a function that converts std_logic_vector(7 downto
0) s (outputs of the ram) to character. tochar is defined as bellow:
------- tochar function
function tochar (vec: std_logic_vector (7 DOWNTO 0)) return character is
variable ch: character;
begin
    case vec is
       when "00000000" => ch:= '0';
      when others => ch:= '1';
   end case;
return ch;
end tochar;
The check syntax of the code is ok, but no .txt file is produced. I
would be pleased if you could help.
  • [vhdl]VHDL code[/vhdl]
