Forum: FPGA, VHDL & Verilog Ethernet: No data useful on eth_rxd (Arty Board)
Author: Jonas (Guest)
Hey guys,
I am experimenting with UDP on my Arty FPGA
board.(https://reference.digilentinc.com/arty) After some fiddeling the
transmitting of data to my laptop already works.
My problem now is that the rx_data bus does not seem to give me other
data than "0000" and "1111". I have also connected the rx_dv to an led
and I see it blinking so I assume there should be more useful data than
just these two values on the bus. I am also sure that there are packets
sent. I see them in wireshark.
Did you guys already have a similar problem and can point me in a
general direction?
Greetings,
Jonas
: Moved by Moderator
Author: Duke Scarring (Guest)
How did you check the rx data?
Also with LED? Or with chipscope?
Duke
Hey Duke,
Thanks for your answer.
I checked it by letting an led light up permanently after a nibble that
was not "0000" was found.
I have an LED that is connected to rx_dv and that blinks.
I was not aware that chipscope exists. I will try to learn more about it
and use it, but for now I have implemented a UDP Sender that
successfully sends data, that I also see in Wireshark. I now have
connected the rx_dv to tx_en and rxd to txd and update these on
falling_edge(tx_clk). This successfully bounces back all packets, but
instead of any data, every nibble is "0000".
I have attached a Wireshark save file of two example packets sent to the
FPGA and the two answers. The ethernet frame checksum is wrong because I
set the UDP packet length to 18. I will try to fix this with an
automated counter, but it should make no difference.
Author: Jonas Dann (jonasdann)
I have now also debugged it with the Vivado ILA. I have registered a
trigger to rxd not being "0000" and it never triggers. When I register a
trigger to rx_dv it triggers normally. This is really weird.
Do you guys have any ideas?
Jonas
Did you use the correct pins for rxd?
How fast is your ethernet?
How fast is your fpga system clock?
Duke
Thanks a lot for your help.
Yes I used the correct pins. The .xdc comes directly from the vendor.
But this was a good tip. I checked the pins and saw that the rdx pins
were declared at OUT in the elaborated design. I do not know why, but I
declared the rxd port as a buffer instead of a in port in the VHDL. I
now declared it as an in port and it works like a charm.
I now feel a bit stupid, but also know more about FPGAs. :D
Jonas
  • [vhdl]VHDL code[/vhdl]
