Forum: FPGA, VHDL & Verilog comparison of two unsigned std_logic_vectors
von Farzam (Guest)
Hi everyone. I'm having problem comparing two unsigned same length
std_logic_vectors. I'm using the std_logic_unsigned package which
contains a set of comparison functions for same length std_logic_vectors
including the function below:
function "<"(L: STD_LOGIC_VECTOR; R: STD_LOGIC_VECTOR) return BOOLEAN
Here's my code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity main_code is
  Port ( clk : in  STD_LOGIC;
         output : out  std_logic_vector (7 downto 0);
         ero : buffer  std_logic_vector (7 downto 0) := (others => '1')
end main_code;
architecture Behavioral of main_code is
signal address: std_logic_vector(3 downto 0) := (others => '0');
signal dout_rom: STD_LOGIC_VECTOR(7 DOWNTO 0) := (others => '0');
--- component declaration (rom_core was generated by ISE core generator)
COMPONENT rom_core
  PORT (
    clka : IN STD_LOGIC ;
    addra : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
    douta : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
begin
------ port map
your_instance_name : rom_core
  PORT MAP (
    clka => clk,
    addra => address,
    douta => dout_rom
output <= dout_rom;
process(clk)
begin
          if(clk'event and clk='0') then
      address <= address + 1;
    end if;
end process;
if (dout_rom < ero) then   -- line 83
ero_sig <= dout_rom;
end if;   -- line 85
end Behavioral;
and here are the errors I get:
Line 83: Syntax error near "if".
Line 85: Syntax error near "if".
The rest of the code (the code minus the last if-clause) is compiled
successfully. I can't figure the errors out. I would be really pleased
to hear from you.
von Staubfänger (Guest)
Hi Farzam,
the error message implies, that the if statement is the problem. If it
would be the comparison, the error message would mention something about
mismatching data types or mismatching vector lengths.
In fact, the part outside of a process, is to bee seen as a concurrent
section, within an if-statement is not allowed.
von Farzam (Guest)
Thanks a lot for the answer Staubfänger. I see what you're saying. The
problem is solved. Thanks a lot again.
@ Farzam
Was a pleasure.
