Forum: FPGA, VHDL & Verilog Hardware-Software Partitioning on FPGA for communication receivers and network switches (webinar)
Author: Jegan (Guest)
Complexity of systems implemented using FPGA's are exponentially growing
in a rapid pace. As a result of it most of the common design issues that
a designer come across with ASIC SoC are becoming relevant with FPGA as
well.  Beginning with the Virtex 4 and now with Zynq UltraSoc, there is
considerable processing power on the compute side.  A simple migration
is in insufficient to achieve the same performance as discrete chips.
Estimating or identification of system performance and crucial
bottlenecks much before writing RTL not just reduces the development
time but also increases the Quality of Results. During this event we
will be talking about how performance analysis and architecture
exploration  in the early stage of system development ensures that you
select the right FPGA platform and achieve optimal partitioning of the
application onto the fabric. These system level models generally do not
need the implementation level details such as the application software,
pin level connectivity and detailed signal data. The models developed at
this stage can be used for product specification development in order to
select the right platform, end-to-end latency, hardware and software
partitioning.
In this Webinar, we shall demonstrate the performance with various
hardware-software partitions for variety of user cases and workloads.
We shall also look at the latency time and the power consumed for
different configurations of buffering, DDR memory interface and
FPGA-FPGA synchronization.
Takeaways:
1. Detection of synchronization errors with system-level modeling
2. Performance improvement using the on-FPGA processors such as PowerPC
and ARM
3. Partitioning the application or protocol between the soft-core
processors and Fabric
4. Memory controller algorithm for control algorithms
5. Determine the utilization and effective throughput across the
hardware resources
Webinar provides significant information on the deciding factors while
selecting a FPGA or designing complex FPGA systems and also significance
of system level design explorations much before RTL development. This
webinar will be of interest for System Architects, Senior Hardware
Engineers and Senior FPGA design engineers.
To register, http://mirabilisdesign.com/new/webinar-registration/
  • [vhdl]VHDL code[/vhdl]
