Forum: FPGA, VHDL & Verilog VHDL - 10% duty cycle
Author: Sen93 (Guest)
Hello, I'm new to VHDL. I need to generate 500Hz from 50MHz clock
frequency. I already got it. My problem here is how should the code to
be adjusted if I want to change the duty cycle to 10%, 30%, and 50%?
Thank you.
Author: Chris (Guest)
You should reformat your code. You cannot read which "else" belongs to
which "if".
I don't kniwnif its even possible to add 1 to a std_logic_vector.
What you need, are 2 values. One for counting up and one for down.
Typically you set a flag if you are counting up or not.
Indeed 2 values are needed.
But only 1 for a counter, and the second for a compare value to toggle
the output. Then its stupidly easy:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
entity PWM500Hz is
    port( clock   : in STD_LOGIC; -- 50 Mhz
          pwmout  : out STD_LOGIC);
end PWM500Hz ;
architecture Behavioral of PWM500Hz is
  signal cnt: integer range 0 to (50000000/500)-1 := 0;
  constant cmp: integer := (50000000/5000); -- PWM = 10%
begin
  process(clock) begin
    if rising_edge(clock) then
      if cnt<(50000000/500)-1 then cnt<=cnt+1;
      else cnt<=0;
      end if;
    end if;
  end process;
  pwmout <= '1' when cnt<cmp else '0';
end Behavioral;
  • [vhdl]VHDL code[/vhdl]
