Forum: µC & Digital Electronics Level Shifter Questions
Author: ab0032 (Guest)
Googling around I have found that people connect 3.3V sensors to 5V
Arduinos without level shifters, how can that be? All cases without
level shifter I found used I2C. Do I need level shifters only for SPI?
Does that somehow have to do with I2C pullup resistors?
A 3.3V high signal from a sensor will be recognized as a high on the
Arduino, but how reliable is that?
Going from the Arduino to the sensor I would fear that a 5V high from
the Arduino would damage an input on a sensor chip.
In particular I want to connect the Decawave DWM1000 and the MPU9250 to
Arduino. The datasheets say that 5V is not okay on the inputs.
I have this breakout board which seems to have a voltage regulator to
supply the 3.3V to the MPU9250, but do I need to use level shifters to
connect this to an Arduino?
Ebay-Artikel Nr. 181955388388
Are certain level shifter preferable to others for SPI? Schmidt
triggers?
Author: Kaj (Guest)
I recommend the application note AN97055
Author: Clemens L. (c_l)
I²C uses pull-up resistors to define the high level, but this still
means that all devices on the bus use the same high level.
If the devices require different signal levels, all connections/buses
need level shifters.
A CMOS input switches at a threshold voltage, which is typically
guaranteed (for VCC = 5 V) to be somewhere between 1.5 V and 3.5 V. So
to switch reliably, the high level of the signal would have to be at
least 3.5 V.
In practice, the actual threshold voltage is likely to be near the
middle (2.5 V), so it's likely to work. But "likely" is not
"guaranteed". And a voltage that is not near GND or VCC can increase the
power consumption greatly.
There are inputs that are 5V tolerant. (If that were the case, it would
be documented in the datasheet.)
If the input is not 5V tolerant, connecting a 5V signal is likely to
burn out the ESD protection diodes and probably other components (if the
source can supply enough current).
Unidirectional downshifting can be done with a simple voltage divider
(if the speed does not need to be too high).
: Edited by User
Author: Alexander Biersack (ab0032)
Thank you both for the answers.That clarifies matters for me.
So if I briefly summarize this, please correct me if I am wrong, I
should use level shifters between 5V and 3V devices.
For SPI I need 4 unidirectional level shifters and for I2C I need two
bidirectional level shifters.
The level shifting from the application notes AN97055 suggests using
mosfets with a switching time of less than 50ns for I2C.
Would that also work for SPI or would that be too slow? Since the level
shifting for SPI is directional, I could use both directional and
bi-directional level shifters, right?
Are Schmidt triggers a recommended way for directional level shifting?
Or devices like the 74LVC245 with a delay of less than 17ns (
https://cdn-shop.adafruit.com/datasheets/sn74lvc245a.pdf )?
Is there some preferred way to do level shifting if I design my own
breakout board?
For playing around on a breadboard it does not really matter, so I can
use more or less any $1 to $2 level shifter I can get on ebay, as long
as it is fast enough, right?
