Forum: FPGA, VHDL & Verilog 8x1 Multiplexer
Author: Min_ah (Guest)
Hello,
I want to design 8x1 multiplexer. But, I just only have 5 options of
input, which are freq1, freq2, freq3, freq4, and freq5. Is it possible
to design it with only just have 5 options of input?
Thank you.
I'm using Xilinx and VHDL language.
Min_ah wrote:
> Is it possible to design it with only just have 5 options of input?
Its like dricng a car possible to speed up to 200km/h only with
125km/h...
Yes, if you use only 5 inputs, then the remaining 3 are unused and tied
to '0'. Or they are the "when others" case and mirror one of the
selections...
> 5 options of input, which are freq1, freq2, freq3, freq4, and freq5.
You want to multiplex (clock) frequencies?
Yes, I want to multiplex clock frequency.
Min_ah wrote:
I'm sorry, I will not download a docx file. That is not a format to
interchange documents. Try a pdf instead...
Usually that is a very, very bad idea. If you are a beginner you should
not do a design needing 5 different clocks. It will break your bones.
To get a clearer picture write as much information as possible. What do
you need thes clocks for? Are that really clocks? Where do the signals
come from? Where do they go to?
I need to design the Multiplexer like the picture I give above.
Author: Achim S. (Guest)
it's quite straight-forward to describe such a multiplexer in VHDL. When
I google the words "VHDL multiplexer" pretty much every link I get gives
a useable guideline. If I follow two or three links, then I even get a
source which can get copied without much modification.
But as Lothar already mentioned: multiplexing Clock signals in a real
design will not work like that (even if the simulation may tell you
something different). With such a Multiplexer you can deliver a logic
signal Yout as output. But a logic signal and a Clock are something
different inside an FPGA (they do not even share the same signal lines).
If you want to run it in real hardware, then you'll need a different
approach.
This is (as already said) NOT a way to generate signals for use as a
clock inside a FPGA.
Instead I urge you to have a look for the clock enable strategy: only
1 clock (about 50..100MHz) throughout the whole design and then a bunch
of signals generated by counters, each signal active for a single clock
cycle.
  • [vhdl]VHDL code[/vhdl]
