Forum: FPGA, VHDL & Verilog Use Xilinx Microblaze performance monitoring engine from AXI4Lite
von Giacomo V. (giav)
I would like to use the MicroBlaze performance monitoring engine to
collect some information on my application code running on the processor
itself. I would need these information at application level. I have a
problem to access these values.
In order to do these things, I have created a project with MicroBlaze
and extended debug function, with 5 event counters and 1 latency
counter.
Then I have inserted a MDM in my design and created an AXI4lite slave
port to access from MicroBlaze itself. In this mode I should be able to
access to internal performance monitoring engine by using DBG_CTRL and
DBG_DATA registers indicated to page 12 of pg115 (MDM product guide),
with values indicated on page 92 of MB reference guide (version
2015.04).
Suppose I need to measure number of any valid executed instruction, I
have wrote the code attached to this post.
The problem happens when I perform the read from *dbg_data: the read
action on this variable does not give any response.
The register pointed by variable is R/W.
Do you have any suggestion about this wrong behaviour?
Thank you.
von Duke Scarring (Guest)
Try to define your *dbg_data as volatile.
Duke
thank you for the suggestion. I have tried and the behaviour is the
same.
The problem is the AXI engine under the AXI4slave peripheral (in this
case, the microblaze debug module): it does not answer to a request.
In the previous post, I have indicated that the problem is the read
action from *dbg_data. By making a simulation, it appears that the
problem also happens during an AXI write on *dbg_data memory area.
More specifically, considering attached file, and focusing on MDM
section, it can be noted that a write on address 41400010 (the content
of dbg_ctrl variable) happens correctly, because there is a READY
response from slave to a VALID transition.
Then, there is a write on address 41400014 (the content of dbg_data
variable): there is no READY response.
The above first two writes are related to the first lines of the code:
    *dbg_ctrl=0x4a404;
    *dbg_data=1;
This causes a block in the application execution, because following AXI
guidelines, if a master issues a request to write and raises up the
VALID signal, it must wait the READY response from slave. So without
READY answering, the master is blocked.
Do you have other suggestion?
Thank you,
Giacomo
von masterLuke (Guest)
In case someone is interested in a solution, just like me looking
through some old posts trying to fix my bugs...
you need to unlock the register access by writing the "magic value" into
the lock register (adress: 0x41400018). according to the manual (section
debug register access sequence of MDM manual)this has to be the value
0xebab.
then the access to the dbg_data-register should be granted.
