Forum: FPGA, VHDL & Verilog 8 bit DIVISION PROBLEM
von Marius P. (marius91000)
Hi guys,
I have a little problem with a division in VHDL. More exactly , my
problem is that my first element which I want to be divided is not
memorised and I really don`t know why because I have no problem with the
second one.
Let me explain you :
I want to divide broj1 by broj2. Below is the code , please help me !
Thanks.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Multiplier is
port ( input : in std_logic_vector(7 downto 0);
            btn1,btn2,btn3 : in std_logic;
            output,remainder : out std_logic_vector(7 downto 0));
end Multiplier;
architecture Behavioral of Multiplier is
signal broj1:std_logic_vector (7 downto 0);
signal broj2:std_logic_vector (7 downto 0);
signal i:std_logic_vector (7 downto 0);
signal aux:std_logic_vector (7 downto 0);
begin
process (btn1, btn2)
begin
if (btn1'event and btn1='1') then
        broj1<=input;
end if;
if (btn2'event and btn2='1') then
        broj2<=input;
end if;
end process;
process (btn3)
begin
if (btn3'event and btn3='1') then
  --output <= broj1 / broj2;
  i<="00000000";
    while (broj1>= 0) loop
        i<=i+1;
    aux<=broj1;
    broj1<=broj1-broj2;
    end loop;
  i<=i-1;
  output<=i;
  remainder<=aux;
end if;
end process;
end Behavioral;
What did you expect it to do? And what does it instead?
How did you find that out?
You know in what a loop in VHDL results?
And the ABSOLUTE MAJOR HINT:
Forget that btn'event. Only a clock is worth of an 'event. And in a
beginners design there MUST be only 1 clock throughout the WHOLE design.
To check a pressed button that buttons signal must be synchronized to
the one and only clock. Then a debouncing should be used and an edge
detection afterwards.
All in all that are a bunch of flipflops, also known as a shift
register.
But that thing with those 'event on each input will run ONLY in
simulation (if at all).
And one word more: VHDL is not a programming language. If it was then it
would be called VH-P-L...
