Forum: FPGA, VHDL & Verilog BASYS 2 Implementation
von Nirav B. (Company: Uvic) (nirav_bhatt)
Hello ALL,
I am a beginner with fpga boards.I have a code and i need to run it on
BASYS 2 board . Basically its a code for generating gating signals. I
need help how to assign input and output ports and how do i check
whether i am getting correct output.
Attached is the code for reference.
Help will e highly appreciated.
Nirav B. wrote:
> I need help how to assign input and output ports
What toolchain?
> and how do i check whether i am getting correct output.
Wrap a testbench around your module and apply some stimuli signals.
One thing you will find out is that you will get some spurios gating
signals when changing the half_duty randomly. This is because you
compare the switching points by equalitiy:
    IF(count(i) = half_duty) THEN
        G1_out(i) <= '0';
    ELSIF(count(i) = half_duty +10 ) then
        G2_out(i) <= '1';
    ELSIF (count(i) = period - half_duty -10) THEN
        G2_out(i) <= '0';
    ELSIF(count(i) = period - half_duty) THEN
        G1_out(i) <= '1';
    END IF;
Better would be to change half_duty only when the counter is reset to 0.
Or at least you must change the half_duty value at a point where all
phases are in an inactive state...
BTW: pls attach a VHDL file as *.vhd or *.vhdl (not as *.txt)
You will see some little magic named "syntax highlighting"...
I am sorry for late reply.Exams compelled me to stay away from this
board.
I am not sure what tool chain means..... I guess i assigned them in plan
ahead also i did not get what you mean by wrapping up test bench.
Attached are the.vhd file and .ucf file for input and output port pins.
1. I am not sure of clock signal.The clock i have used is 50 MHz and the
pin B8 on board says it gives 50 MHz , i am really not sure how to check
the clock.Attached is the image of the board where clock is shown.
2. I should get results like atttached ISIM snapshot. G1 and G2 output
should be conducting at 50% duty cycle.
I am dumbest ever guy in FPGA but i want to learn and get better at it.
Please help me.
