Forum: FPGA, VHDL & Verilog Blocking vs Non-blocking questions (verilog)
von Trevor H. (Company: Raytheon) (trevh88)
1. I can't remember learning this specifically but for some reason I
think you are not supposed to use blocking in sequential blocks? If so
why is this?
2. I was taught that if blocking is used, but would still be
functionally the same as non blocking, it synthesizes the same as non
blocking, i.e a single = statement within an always block. I answered
this way in an interview once and was told I was wrong, that they do
synthesize differently. So, which is it? How does synthesis handle
blocking vs non-blocking?
: Edited by User
von Marcus H. (mharnisch)
Trevor H. wrote:
> 1.
This rule applies to variables driven and read by different processes.
The core of the issue is in Verilog's scheduling semantics (cf.
IEEE1800-2012, sec. 4.4 “Stratified event scheduler”). Blocking
assignments take place in the Active region, that is as soon as the
corresponding statements are executed. Non-blocking assignments will be
scheduled into the NBA region, that is after all statements have
executed.¹
IOW, the non-blocking assignment ensures that all processes that are
looking at a variable will see the value it had before any changes in
the current time step. Much like a VHDL signal (but not quite the same).
> 2.
As far as a single assignment statement is concerned, I'd say this is
true. But if there is an assignment before reading back the variable,
blocking vs non-blocking does synthesize differently.
Footnotes:
¹ Simplified. There are loopholes. Verilog gives you enough rope to hang
yourself.
