Forum: FPGA, VHDL & Verilog 16bit synchronous counter
von Ber 2. (ber25)
Help me please to write te vhdl code about the next delivery:
Consider the circuit in FigureA. It is a 4-bit synchronous counter,
which uses four T-type flip-flops. The counter increments the count
signal on each positive edge of the clock if the Enable signal is
asserted. The counter is reset to 0 by using the Reset signal. You need
to implement a 16-bit synchronous counter and alfter that you must
augment a vhdl file to use the pushbutton KEY0 as the Clock input,
switches SW1 and SW0 as Enable and Reset inputs, and 7-segment displays
HEX3-0 to display the hexadecimal count as your circuit operates.
Can i use 16t.flip_flop and Q(0)Q(1)Q(2)Q(3) for HEX0
                            Q(4)Q(5)Q(6)Q(7)Q(8) for HEX1
                            Q(9),Q(10),Q(11),Q(12) for HEX2
                            Q(13),Q(14),Q(15),Q(16) for HEX3 ?
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY Counter IS
PORT (Enable, Clock, Clear: IN STD_LOGIC;
    Q: STD_LOGIC_VECTOR(15 downto 0));
END Counter;
ARCHITECTURE Behavior OF Counter IS
SIGNAL count: STD_LOGIC_VECTOR(5 DOWNTO 0);
BEGIN
  Q<= COUNT;
  PROCESS(Clock,Clear)
  BEGIN
  IF Clear='1' THEN
     count <= '000000000000000';
  ELSIF Clock'EVENT AND Clock='1' THEN
  -- I can't use Q <= Q+1;
  END if
  end process
  end behavior;
von Gustl B. (-gb-)
Hello, you just have to describe a T-FF and then connect them as a
chain.
The description of the counter (just 8 bits):
library ieee;
use ieee.std_logic_1164.all;
entity counter_16bit is Port(
  clock: in STD_LOGIC;
  enable: in STD_LOGIC;
  reset: in STD_LOGIC;
  Q: out STD_LOGIC_VECTOR(7 downto 0));
end counter_16bit;
architecture behavior of counter_16bit is
signal BIT_0, BIT_1, BIT_2, BIT_3, BIT_4, BIT_5, BIT_6, BIT_7: std_logic:= '0';
begin
Q <= BIT_7 & BIT_6 & BIT_5 & BIT_4 & BIT_3 & BIT_2 & BIT_1 & BIT_0;
--FF_0:
process (clock, enable, reset)
  begin
  if   reset = '1' then
    BIT_0 <= '0';
  elsif rising_edge(clock) AND enable = '1' then
    BIT_0 <= NOT BIT_0;
  end if;
end process;
--FF_1:
30
31
  begin
32
  if   reset = '1' then
33
    BIT_1 <= '0';
34
  elsif rising_edge(clock) AND enable = '1' AND BIT_0 = '1' then
35
    BIT_1 <= NOT BIT_1;
36
  end if;
37
end process;
38
39
--FF_2:
40
41
  begin
42
  if   reset = '1' then
43
    BIT_2 <= '0';
44
  elsif rising_edge(clock) AND enable = '1' AND BIT_1 = '1' then
45
    BIT_2 <= NOT BIT_2;
46
  end if;
47
end process;
48
49
--FF_3:
50
51
  begin
52
  if   reset = '1' then
53
    BIT_3 <= '0';
54
  elsif rising_edge(clock) AND enable = '1' AND BIT_2 = '1' then
55
    BIT_3 <= NOT BIT_3;
56
  end if;
57
end process;
58
59
--FF_4:
60
61
  begin
62
  if   reset = '1' then
63
    BIT_4 <= '0';
64
  elsif rising_edge(clock) AND enable = '1' AND BIT_3 = '1' then
65
    BIT_4 <= NOT BIT_4;
66
  end if;
67
end process;
68
69
--FF_5:
70
71
  begin
72
  if   reset = '1' then
73
    BIT_5 <= '0';
74
  elsif rising_edge(clock) AND enable = '1' AND BIT_4 = '1' then
75
    BIT_5 <= NOT BIT_5;
76
  end if;
77
end process;
78
79
--FF_6:
80
81
  begin
82
  if   reset = '1' then
83
    BIT_6 <= '0';
84
  elsif rising_edge(clock) AND enable = '1' AND BIT_5 = '1' then
85
    BIT_6 <= NOT BIT_6;
86
  end if;
87
end process;
88
89
--FF_7:
90
91
  begin
92
  if   reset = '1' then
93
    BIT_7 <= '0';
94
  elsif rising_edge(clock) AND enable = '1' AND BIT_6 = '1' then
95
    BIT_7 <= NOT BIT_7;
96
  end if;
97
end process;
98
99
end behavior;
And here the testbench:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
use IEEE.numeric_std.all;
ENTITY counter_16bit_bench IS
END counter_16bit_bench;
ARCHITECTURE behavior OF counter_16bit_bench IS
  COMPONENT counter_16bit is Port(
  END COMPONENT;
  signal clock, enable, reset : std_logic := '0';
  signal Q : std_logic_vector(7 downto 0);
  constant clk_half_period : time := 5 ns;
  signal clk: std_logic:='0';
  signal state: integer range 0 to 2:=0;
  signal counter: integer range 0 to 63:=0;
BEGIN
  uut: counter_16bit PORT MAP (
    clock => clock,
    enable => enable,
30
    reset => reset,
31
    Q => Q
32
33
34
  clk <= not clk after clk_half_period;
35
36
  process begin
37
  wait until rising_edge(clk);
38
39
  if state = 0 then
40
    counter <= counter +1;
41
    enable <= '1';
42
    clock <= to_unsigned(counter,6)(0);
43
    if counter = 43 then
44
      state <= state +1;
45
      counter <= 0;
46
      reset <= '1';
47
    end if;
48
  elsif state = 1 then
49
    reset <= '0';
50
51
52
    if counter = 13 then
53
      enable <= '0';
54
    end if;
55
    if counter = 27 then
56
      state <= state +1;
57
      enable <= '1';
58
    end if;
59
  elsif state = 2 then
60
61
62
  end if;
63
  end process;
64
END;
So ... i did the firt 8 bits of the work, now do the remaining half :-)
von Ber 2. (ber25)
> chain.
Thanks,you re really kind. Your vhdl is really helpful!
Can you help me with the second part also, please?
von alexxk (Guest)
Hi!
to implement this, you need to write a constraint file! For this you
need the datasheet of your development board!
Additionally you need to write a a module to show each hex value on one
of the 7 segment digits!
this is ver easy with a case statement.
http://www.ics.uci.edu/~jmoorkan/vhdlref/cases.html
Why cant you use Q <= Q+1; ?
it would be way easier to do this this way and just care for the
overflow:
(ill do it for 8 bit)
signal counter : std_logic_vector (7 downto 0);
process(clk)
begin
if(rising_edge(clk)) then
if(counter="11111111) then
counter <= "00000000);
end if;
else
counter <= counter+1;
end if;
end process;
You can then just take the hex values: (for 16 bit counter)
signal hex3,hex2,hex1,hex0 : std_logic_vector (3 downto 0);
hex3 <= counter (15 downto 12);
hex2 <= counter (11 downto 8);
hex1 <= counter (7 downto 14);
hex0 <= counter (3 downto 0);
and map each to one 7_segment_decoder.
In your constraint file (.ucf) you just map your pins to the according
vhdl signals. If you need further help with this you need to provide
information what board you use!
if you use a button for clk input you should debounce it!
What error messages do you get here?
This is due to 2 major problems:
1. You must use an arithmetic package for calculations!
2. You cannot read outputs, but for the 'Q+1' you need to do this. Do
you remember: you have a local counter signal named count for
counting?
Take the numeric_std and use an integer for counting:
LIBRARY ieee;
USE ieee.numeric_std.all;
ENTITY Counter IS
END Counter;
SIGNAL count: integer range 0 to 65535 := 0;
BEGIN
  Q <= std_logic_vector(to_unsigned(COUNT,16));
  PROCESS(Clock,Clear) BEGIN
    IF Clear='1' THEN
       count <= 0;
    ELSIF rising_edge(Clock) THEN
       if count<65535 then
          count <= count+1;
       else -- wrap around
          count <= 0;
       end if;
    END if
  end process
end behavior;
At least you must tell the toolchain what PINs you want to use and what
CLOCK frequency you have...
: Edited by Moderator
von -gb- (Guest)
I think in this homework he should actually describe the single FF. And
perhaps use it as a component.
That would be one of those stupid exercises leading to that extremely
chatty and unreadable "academic university VHDL".
von -gb- (Guest)
Yeah, right, but i smell university ...
