Forum: FPGA, VHDL & Verilog VHDL UART testbench that send/receive to/from a software on the Windows
von Mostafa S. (semofa)
I need to write a VHDL code on FPGA side that can receive data from a
UART port and write them to a SDRAM and send back that data to a UART
port. a software is on the computer side that send and receive data.
BUT, I do not have a board to test. I need to write a testbench to test
my design. my problem is: how can I communicate between Testbench and my
software on the Windows? I need my Testbench read and write on a UART
port.
von dose (Guest)
VHDL Testbench can read and write from a file.
Mostafa S. wrote:
> I need my Testbench read and write on a UART port.
Do you really need such a thing? Or do you just want it, until you
have real hardware?
I've never seen something like that, and of course it is VERY tricky,
because a computer terminal runs in real time. And your simulation runs
in calculated time tics. E.g. if theres much to calculate a millisecond
in simulation takes one second in real time. So your simulation in this
case is 1000 times to slow for the comunication with the terminal
software. I see it as a reasonable challenge to get such a thing
running.
What is "a UART port" here?
Is it the TX and RX register of the UART? Or is it a double buffered
UART?
As already said usually a testbench gets values from a file and it
writes results to a file. And all of that with no relation to real
time...
von René D. (Company: www.dossmatik.de) (dose)
> have real hardware?
for Lothar:
I have written an Ethernet port in my simulation. This is very tricky.
von Vancouver (Guest)
So you are looking for a kind of bridging between your test bench and a
virtual UART interface on the PC. This is mainly a question of simulator
support, since you have a kind of co-simulation here. To my knowledge,
only a few simulators support that. As proposed above, you may emulate
this interface by redirecting the UART data to files (one for sending,
one for receiving)  in the test bench as well as on the PC. This sounds
complicated and I am in doubt if this is necessary for such a simple
design. Moreover, you cannot simulate the impact of the real interface
hardware.
You should do the verification in two levels:
Level 1 is the low level UART communication and memory interfacing.
Write a simple test bench here consisting of your design and verified
UART and SDRAM simulation models. Let them communicate and check that
reading and writing of data packet works. If possible, do a timing
simulation.
Level 2 requires the target hardware. Here check if your PC software
works together with the design on the real FPGA target. This is mainly a
verification that your software is working correctly, but this is
nothing that requires to be checked within a test bench environment.
von Strubi (Guest)
Google for Co-Simulation. There are plenty of tools out there, but some
cost real money. If you want it cheap, check GHDL and GHDLEX, this
includes a virtual com port (via unix pipes) to connect to your
simulation. You need a fast machine though, a full SoC and UART
simulation will result in very few effective bytes per second (depending
on the UART baud rate). You can skip the async UART counterpart of
course and use the pipe directly. GHDLEX has a few more virtual
interfaces as virtual FIFOs, they might be more effective for fast data
I/O.
For Windows though, you need Linux to compile, as ghdl/ghdlex won't
compile your simulation natively for Windows for various reasons. This
is not trivial and you're pretty much on your own there.
You can also run co-simulation from Python/myHDL, you might also want to
check cocotb.
Greetings,
- Strubi
