Forum: FPGA, VHDL & Verilog Change a front of clock signal
Author: Dima Ustinoff (ustinoff)
Hello. I do not understand, how i can do next thing.
My block have 3 input ports and 1 output port. Input ports are
fast_clock,slow_clock,enable. Output port is clock_out. So, i want to
change a front of slow_clock in time of change "enable" (it's changing
from 0 to 1 and have it value all time long) or 1-3 times of
"fast_clock". Front changing's rule is: if slow_clock = '1' then
clock_out = '1' else clock_out = not(slow_clock). My blocks after this
blocks must feel changing a front ( in VHDL language: rising_edge(clk)
I want to get "clock_out" with the same frequancy that "slow_clock", but
if "enable" changing from '0' to '1' or after 1-3 times of "fast_clock"
my next blocks must feel changing from low front to high front.
I tried to do it with next code:
process(enb,fast_clock,slow_clock)
begin
  if rising_edge(fast_clock) then
    if enb='1' then
      if slow_clock='1' then
        clock_out <= slow_clock;
      elsif slow_clock='0' then
        clk_out <= not(slow_clock);
      end if;
    else
      clk_out <= '0';
    end if;
  end if;
  end process;
Author: Andreas Schweigstill (Company: Schweigstill IT) (schweigstill)
Your current VHDL code can be reduced to:
process(enb,fast_clock)
begin
    clk_out <= enb;
  end if;
end process;
Nobody understands what you really want to do.
: Edited by User
Andreas S. wrote:
> Your current VHDL code can be reduced to: ...
Even this can be reduced further on: take enb out of the sensitivity
list. A clock would be enough...
Dima U. wrote:
> So, i want to change a front of slow_clock in time of change "enable"
> (it's changing from 0 to 1 and have it value all time long) or 1-3 times
> of "fast_clock".
Uhhmmmm, could you draw that as a schematic or a block diagram? Then it
is easy to describe with VHDL (as VHDL is a description language).
Or maybe you can draw a timing diagram where it can be seen, what
shlud happen.
>> of "fast_clock".
> shlud happen.
I have 2 independent data streams, and i must start to send both synch
with special mark of time. The mark has 100 ns high front and 1 second
has low front; and it's periodic signal.
Freq.-s of both signals is non-constant.
I try to do next thing: when the first high front of mark come i make
"enable" signal. After changing the "enable" signal starts to work some
blocks, and both of streams i'm writing in RAM (not at all 1 second
long,of course). When next mark coming i make "enable" for reading from
RAM and in start post's i wrote my attempt to generate clock for
reading.
Timing diagram here.
/Mark of time/: 100 ns high front and 1 second has low front signal;
enable_1 - blocks start to work from this signal;
write_enable - enable to write RAM;
read_enable - enable to read RAM;
clock for reading - (red color) this signal i want to use for reading
from RAM and it i tried in the first post.
And finally, out data - one (for simplify) data stream what i have.
  • [vhdl]VHDL code[/vhdl]
