Forum: FPGA, VHDL & Verilog 4 bit up down counter with a programmable modulo value
Author: Ahmed Alibrahim (Company: none) (amd1416)
I am designing an up down counter that has a modulo value that can be
programmed so that value is the highest it can reach to count up to or
down from. I want it so that only if I reset the code the modulo value
is loaded. So if I change it and don't reset the old modulo value will
remain. Also with my counter code I want to implement a clock divider
that I have been given and need to use.
Here are my codes:
This is the code of the counter with the clock divider as a component
within it:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity counter4bit_modproc is
   GENERIC(LIMIT : integer := 2);
   port(
        mod_value:        in  std_logic_vector(3 downto 0);
        clock:            in  std_logic;
        enable_count:     in  std_logic;
        reset:            in  std_logic;
        direction:        in  std_logic;
        output_counter:   out std_logic_vector(3 downto 0) );
 end counter4bit_modproc;
 architecture behavioral of counter4bit_modproc is
   component Clock_Divider is
      generic ( LIMIT : integer := 2 );
      port (
            Clock   : in std_logic;
            Reset   : in std_logic;
            Clk_Div : out std_logic);
   end component;
   signal dig: std_logic_vector(3 downto 0);
  signal clk: std_LOGIC;
   begin
   clkdiv: Clock_Divider generic map (LIMIT => 50000000)
                 port map (
                                   clock   => Clock,
                                   Reset   => Reset,
                                   clk_Div => clk);
   process(clk, Reset)
      begin
         if Reset='1' then
            dig <= "0000";
         elsif ( rising_edge(clk)) then
            if (enable_count = '1') then
               if (direction = '0') then
                  if (dig <= mod_value) then
                      dig <= "0000";
                      --dig <= (others =>'0');
               else
                      dig <= dig + 1;
                  end if;
               elsif (dig = "0000") then
                      dig <= mod_value;
               else
                      dig <= dig - 1;
               end if;
           end if;
        end if;
   end process;
      output_counter <= dig;
 end behavioral;
here is the code for the clock divider:
library IEEE;
entity Clock_Divider is
  PORT (
      Clock    : IN  STD_LOGIC;
      Reset    : IN  STD_LOGIC;
      Clk_Div : OUT  STD_LOGIC
end Clock_Divider;
architecture Behavioral of Clock_Divider is
signal cnt : STD_LOGIC_VECTOR(31 downto 0);
begin
PC: process (Clock, Reset)
   begin
    if rising_edge(Clock) then
      if Reset = '1' then
        cnt <= (others => '0');
        Clk_Div <= '0';
      elsif cnt = LIMIT-1 then
        Clk_Div <= '1';
      else
        cnt <= cnt+1;
        Clk_Div <= '0';
      end if;
    end if;
   end process;
end Behavioral;
: Edited by Moderator
1 useful
Don't use those old obsolete Synopsys libs (although they are in all the
school books). Use the numeric_std instead...
> Here are my codes:
Whats the problem with it? What do you expect? And what does happen
instead? Do you have a test bench for simulation?
In this totally synchronous process only clock is needed in the
sensitivity list.
This ist not the way a clock is generated inside an FPGA! If you MUST
generate a slower/different clock then use a clock manager. The rest is
done by clock-enables.
To keep things short: a beginners design has only 1 clock active on the
same edge all over the design.
> I want it so that only if I reset the code the modulo value is loaded.
Then you must implement a local register set for storing the mod value.
Just as a hint:
library IEEE;
   port(
      port (
   end component;
   signal mv:  std_logic_vector(3 downto 0);   -- store the mod_value
   begin
                 port map (
                                   clock   => Clock,
                                   Reset   => Reset,
                                   clk_Div => clk);
   process(clk, Reset)
      begin
         if Reset='1' then
            dig <= "0000";
            mv  <= mod_value;    -- quick'n DIRTY! never do this in real life!
                  if (dig <= mv) then
                      dig <= "0000";
               else
                      dig <= dig + 1;
                  end if;
                      dig <= mv;
               else
                      dig <= dig - 1;
               end if;
           end if;
        end if;
   end process;
 end behavioral;
But there are 2 things:
1. don't use a reset and specially a async reset for latching values
2. you MUST sync in the reset signal to the FPGA system clock
The worst thing that can happen is a totally async reset. This will
geive you a design that may occasionally start in an undefined manner
with strange behaviour...
Best for an beginner is to use NO RESET at all.
Thank you for getting back to me.
I want this to count up or down depending on the direction to a
specified value set by the modulo. Also, the clock that is driving the
system should be the output from the clock divider.
The way you have done the modulo value would that change and update the
code only when it is rest?
I need a reset in the code.
Author: Klaus (Guest)
It would have been "nice" if you posed a question. You only described
what you want to do.
However, the code you have shown, wouldn't do what you described - so
you may have intended to ask, either how, or why i does not what you
want.
Its valuable to exercise some analysis of the problem, beforehand.
If the design takes the mod_value input to compare it with the current
counter value, which impact has it, if it is changed? Clearly, that this
new value will be used at the next clock. Nothing in the design enforces
the compare value to be dependent on reset as you described it.
Therefore it will not depend on it. Easy!
So how to enforce the compare value to be constant? It shall only change
on reset? As well, easy! Use a register to store that compare value from
mod_value input and use that register contents as compare value.
Ok thanks for that and how would I make a register as a process to go
along with the counter?
Nothing as easy :-)
Just add a signal like "dig" to your counter4bit_modproc which holds the
modulo-value (say you name it "current_modulo_value"). "dig" and that
additional "signal" are to be seen as registers; one counts one does not
count but stores the modulo value.
Change the process so, that
1. current_modulo_value will store the input mod_value in when reset =
1. You could add that at the point of the text where you set dig to
zero.
2. current_modulo_value will be used for comparison instead of the input
mod_value.
Its simple: invoke a clock. Then you'll get a register.
library IEEE;
   port(
      port (
   end component;
   begin
                 port map (        clock   => Clock,
                                   Reset   => Reset,
                                   clk_Div => clk);
   process(clk)
         if Reset='1' then
            mv  <= mod_value;    -- this will get you a set of registers
         end if;
      end if;
   end process
   process(clk)
     begin
         if Reset='1' then    -- use a sync reset and keep in mind to sync the reset to the clk!!!
            dig <= "0000";
         else
                  if (dig <= mv) then
                      dig <= "0000";
                  else
                      dig <= dig + 1;
                  end if;
                      dig <= mv;
               else
                      dig <= dig - 1;
               end if;
            end if;
         end if;
     end if;
   end process;
 end behavioral;
BTW: have a look at the RTL schematics to see whether the synthesizer
understands your description of what you want him do do...
thank you so now I have a register so that if the mod value is changed
and it is reset that mod value would go to the main counter code as the
maximum value.
Also the clock that is driving the counter is the clk coming out of the
clock divider?
and now it counts up and down and loops around when the mod value is
reached?
is that right?
Ahmed A. wrote:
> a register so that if the mod value is changed and it is reset
> that mod value would go to the main counter code as the maximum value.
Thats the idea, yes.
> it counts up and down and loops around when the mod value is reached?
I assume there are some problems in your part of the code. One is this
here:
                  if (dig <= mv) then
                      dig <= "0000";
                  else
                      dig <= dig + 1;
                  end if;
This compare seems to be the wrong direction: will dig here ever be
able to become anything other than 0000?
So, as already said: run the design on a (behavioral) test bench to
check that out.
> clock divider?
As already said: that is bad design practice. It should not be done this
way in real life FPGA.
  • [vhdl]VHDL code[/vhdl]
