Forum: ARM programming with GCC/GNU tools Linking libspeeex in coocox
Author: Shashi Abd (chan)
I am compiling speex library for arm-cortex-m4. My development board is
stm32f407. Toolchain used to compile speex library is
gcc-arm-none-eabi-5_2-2015q4.Same toolchain is used to compile my
project. I am compiling my project in coocox ide. Project compilation is
successful without any undefined reference errors. But whenever I call
functions of libspeeex ( for example lib_speex_get_mode()) facing hard
fault and flow goes to default handler. My question is, is it possible
to compile open source package for example libspeex and link statically
in my project? I am not understanding this. If there are issues with
linking it should through undefined reference!!! But that's not the
issue. Please help me out guys.
Author: MacLyon (Guest)
Hard fault may arise from uninitialized resources, accessing
non-existent memory areas, stack problems or many other causes.
If you use an IDE, like Eclipse, then in Debug window (upper left) you
have all stack frames available, the faulty function/module is shown
below the stack frame for hard fault(which is the top one). Click on it
and you will go to the code line which caused the fault (in source
window, in debugger).
Also, ARM documentation is useful - read before, you are the only one to
discover first what caused hard fault, then examine the rest of speex
code.
