Forum: FPGA, VHDL & Verilog parallel data into serial
von rushin (Guest)
hello there i have made code for converting parallel data into serial
data. i have attached my main file and test bench file. can you help
me??. but it is not giving me correct data . can you help me??
What do you expect? And what do you get instead?
The attached code is almost unreadable! You MUST use identation to get
readable code. No one wants to dig through a wild heap of ASCII
characters.
All in all that code looks like an software programmer trying to
program an FPGA. But you must get the point: VH-D-L ist not VH-P-L. It
is a description language, noct a programming language. And to
describe something you must have a picture or a kind of sketch to look
at. Or at least you must have some kind of picture in your mind. Then
you can describe what you see.
Or the other way: when I hear "PISO" then I see a multiplexer or a shift
register in mind. And now I can start to describe that thing...
A hint: think about the names of your signals and ports. Its disturbing
to see somewhat like that:
serial_din1:OUT STD_LOGIC;
A input which is an OUT? Kind of strange...
BTW:
Look there: http://www.lothar-miller.de/s9y/categories/26-SPI-Slave
Its SPI and in SPI the MISO is a Parallel In Serial Out...
