Forum: FPGA, VHDL & Verilog LUT in verilog
Author: Antonio Angelino (lsdv)
Hi guys, I have a problem with
creation of a lookup table in verilog. I want
to export data from matlab to a verilog file. It
is a lut with one input and one output. Can you suggest
me a command for avoiding write about 200 line of code.
Thanks.
Author: Andi Meerbann (Guest)
you could write a Matlab script printing the relevant code snippet
(inside of a case block) in verilog syntax. Something like this
(untested!) Matlab code here:
for i=1:length
 fprintf('8'h%x: out <= 8'h%x\n', i, value(i));
end
The result you copy & paste into you verilog file.
Ok, this is a good way to solve problem of copy,Thanks.
But about the LUT creation itself?
For example if i want a LUT of a function sqrt((1/x)+1) with input fixed
because i have a fixed point representation, how can i get the function
output?
Is there a function ?
excuse me, but i've never done this.
Of course there is a function in Matlab to calculate this. And there is
the function fixdt() in Matlab to create a fixed point representation of
your numbers.
This is more a Matlab problem rather than a Verilog problem, right?
well, I ned info about connection of the 2 softwares... you gave me.
Finally I was able to create this lut.
Now I can continue to study Verilog.
Thank you, Mr Meerbann.
  • [vhdl]VHDL code[/vhdl]
