Forum: FPGA, VHDL & Verilog Multiple posedges in sensitivity list
von Joe (Guest)
I have 2 signals that I need to trigger off of...at the rising edge of
the first, I need to toggle a bit, and at the rising edge of the second,
I need to toggle it again.  I have cut the code down to the minimum
needed to demonstrate the problem:
module gen_reset_gate (
CLOCK_50,
        cref,
        cflt,
        reset_gate
input CLOCK_50
input cref;
input cflt;
output reset_gate;
reg   reset_state;
always @(posedge cref)// or posedge cflt)
  begin
    reset_state=!reset_state;
  end
  assign reset_gate = reset_state;
endmodule
It works as-is just triggering off positive edge of cref, or positive
edge of cflt, but when I remove the comment in the always block and try
to trigger off either rising edge, it does nothing.  Simulation verifies
it does nothing, and my development board verifies it does nothing.
I am new to Verilog, so sorry if this is a basic question.
von Lattice User (Guest)
Simulation does nothing, because reset_state is not initialized. And
negate an unknown value will yield an unknown value.
Hardware does nothing, because the synthesizer uses the sensitivity list
only to infer flip-flops and ignores it if you don't follow the required
coding style. Also a flip-flop with two clock inputs doesn't exist in a
fpga.
von Joe (Guest)
Ok, so I'm trying to wrap my mind around what the required coding style
is.  I can't find any examples to do what I'm trying to do, which is set
an output (reset_gate) at the first rising edge (cref), then clear it at
the second rising edge (cflt).
Any constructive help other than you're not doing it right would be much
appreciated.
von Klakx (Guest)
Can you show the solution in a schematic of digital Elements?
von Joe (Guest)
Alright, I got it, in case it will help anyone, here's what I did
(probably still not in the aforementioned coding style):
        cref,
        cflt,
        reset_gate
input cref;
input cflt;
output reset_gate;
reg   reset_state1;
reg  reset_state2;
  begin
    reset_state1=!reset_state1;
  end
always @(posedge cflt)
  begin
    reset_state2=!reset_state2;
  end
  assign reset_gate = reset_state1 ^ reset_state2;
endmodule
von bko (Guest)
> fpga.
Ok for VHDL but -
not correct for verilog, coding for a flipflop with async reset
see e.g:
http://www.asic-world.com/examples/verilog/d_ff.html
>> fpga.
> Ok for VHDL but -
> see e.g:
This is the coding style for a dff with an async reset. Remove the
 if (~reset) begin
from the body, and you will get a synthesis error. But you don't get a
ff with two clock inputs.
@Joe
There are no coding style issue with your last code. (apart with my
personal opinion that old module style declaration should be outlawed)
It will however still have some issues.
If on powerup the two state registers will have different values, your
output is inverted. This depends on the actual FPGA family.
Also it is very sensitive to spikes on the two inputs, assuming they
come from the outside.
Better would be to synchronise the two inputs to your system clock, and
use edge detection.
reg [2:0] sync_cref;
wire edge_cref;
always @(posedge sys_clk) sync_cref <= { sync_cref[1:0], cref} ;
assign edge_cref = sync_cref[1] & ~sync_cref[2];
On the edge for one signal you then can set your output to 1, and on the
edge for the other signal reset it to 0. This solves both issues.
