Forum: µC & Digital Electronics Gamebuino based on arduino nano
Author: David Roper (retrogadgets)
Based on the Gamebuino at www.gamebuino.com
My implentation using an arduino nano dev board
The boot loader has been flashed eith a modified version of optiboot.
Shall post further developments as I test the board
Next shall be the micro sd reader
: Moved by Moderator
Flashed the nano with information at
http://gamebuino.com/forum/viewtopic.php?f=12&t=932
Experimental boot loader available at
https://drive.google.com/file/d/0BweEjvtKj1KLMnMxN...
At the moment my layout based on this schematic
I can see no (in numbers 0) decoupling capacitors at the ATmega...
You should NOT conntect Aref to Avcc. Instead you sould connect only a
capacitor from Aref to GND:
      Vcc --------| Avcc
           .------| Aref
10n..100n ===
Then you can also make use of the internal reference volatage. And of
course you can use Vcc as refeerence voltage also. Simply select it as
reference source in the ADC settings.
: Edited by Moderator
Lothar I'm only using the schematic as a guide, I dont have any
connection to aref at the moment.
But I'll bear it in mind for later
Ive now rewired the board, it looks alot better
The sd board is attached, formatted to fat 16, loader.hex and
settings.hex are present on the sd card.
With the sd card is inserted, the screen backlight has a slight pulsing
action, take it out and its steady! Both the screen and the sd module
connect to the same clock and mosi.
The sd card is running off 5v via its on board regulator and the screen
off 3.3v from the nano
Next for the buttons
Using the arduino ide and editing the board.txt file
Place this code at the end
gamebuino.name=Gamebuino Nano
gamebuino.upload.tool=avrdude
gamebuino.upload.protocol=arduino
gamebuino.bootloader.tool=avrdude
gamebuino.bootloader.unlock_bits=0x3F
gamebuino.bootloader.lock_bits=0x0F
gamebuino.upload.maximum_size=30720
gamebuino.upload.maximum_data_size=2048
gamebuino.upload.speed=57600
gamebuino.bootloader.low_fuses=0xFF
gamebuino.bootloader.high_fuses=0xDA
gamebuino.bootloader.extended_fuses=0x05
gamebuino.bootloader.file=gamebuino_boot/gamebuino_boot.hex
gamebuino.build.mcu=atmega328p
gamebuino.build.f_cpu=16000000L
gamebuino.build.board=AVR_NANO
gamebuino.build.core=arduino
gamebuino.build.variant=eightanaloginputs
Then using a usbasp programmer, connect the icsp header to the nano
board.
Then goto tools in the ide and select programmer as arduino asp or
usbasp, choose board as gamebuino nano then choose burn bootloader
Hey presto the bootloader is written and when the sd module is wired
pressing c on the clone the bootloader flashes the Gamebuino clone with
the loader.hex for choose what ever is on you sd card, game or settings.
Prior to doing the above
Download and extract to my documents on windows or the sketch folder if
on mac the 3 folders
When using the arduino ide, goto examples to see if gamebuino is there,
if so you have installed the routines for the Gamebuino clone
https://github.com/Rodot/Gamebuino/archive/master.zip
My new layout using single core hook up wire
The left button A , the middle button is down, the right button is C for
exiting games and accessing the SD
Next a nice pcb with probably just a atmega 328 instead of the nano
board
Author: Pete K. (pete77)
What is your problemuino?
1 useful
I have no problem, I am the author and  this is my post
If anyone else would like to build
