Forum: ARM programming with GCC/GNU tools SAM7-EX256 - /bin/sh: arm-elf-as: command not found
von Roslan H. (r0skata)
Hello,
I have some issue with building an ARM demo code.
What i'm running is Eclise Helios with Zyling CDT, yagarto tools,
OpenOCD 0.6.1, Cygwin
basically i downloaded Olimex OpenOCD Development Tools (which included
all of the above) as i need to debug a SAM7-EX256 board.
After building the project i get the message - "/bin/sh: arm-elf-as:
command not found"
I tried to google but couldn't find any solutions to this issue, also
i'm running windows 7, all path environment's are added.
I can build simple stuff like "Hello World" without a problem.
Here's what i get when i try to build my source file for the ARM:
make -j all
Building file: ../MyNewEmpty.c
Building file: ../crt.asm
Invoking: Cygwin C Compiler
arm-elf-gcc -I"C:\Progra~1\yagarto\arm-elf\include"
-I"C:\OlimexODS\examples\LIB_AT91SAM7"
-I"C:\OlimexODS\examples\LIB_LCDGE8"
-I"C:\OlimexODS\examples\LIB_SAM7EX256" -O0 -g3 -Wall -c
-fmessage-length=0 -MMD -MP -MF"MyNewEmpty.d" -MT"MyNewEmpty.d"
-o"MyNewEmpty.o" "../MyNewEmpty.c"
/bin/sh: arm-elf-gcc: command not found
Invoking: GCC Assembler
make: *** [MyNewEmpty.o] Error 127
arm-elf-as -o"crt.o" "../crt.asm"
subdir.mk:22: recipe for target 'MyNewEmpty.o' failed
make: *** Waiting for unfinished jobs....
subdir.mk:29: recipe for target 'crt.o' failed
make: *** [crt.o] Error 127
If anyone can help me with this will be greatly appreciated !
I have mentioned this also in the Eclipse CDT forums where some people
suggested this:
"You are missing the whole GCC compiler toolset, starting with
arm-elf-gcc. Maybe the PATH is not set up to include it.
The GNU compiler set needs the compiler driver (gcc), preprocessor
(cpp), compiler itself (cc1), assembler (as) and linker (ld). For
bare-bones hardware targets you may need some utilities, like objcopy.
The program names are often prepended with codes telling which
configuration the toolset has.
The arm-elf-* toolset is pretty old, maybe your old Eclipse setup is no
more compatible with the current compiler (probably arm-none-eabi-*).
A good option to get pre-built arm-non-eabi tools is from Launchpad:
https://launchpad.net/gcc-arm-embedded "
I have installed the arm-non-eabi that was suggested added to tne PATH
environmentals and still doesnt work.
Also for the GCC compiler toolset i got Cygwin installed isnt that
enough ?
Thank you.
I would really appreciate if you can help !
