Forum: µC & Digital Electronics Which step up converter to choose for a fixed Vout independent from Vin
von Jens Strümper (Guest)
Hi there,
for my project I require a step up converter to power a dc motor powered
vacuum pump to run at 6.5 volts (this gives the best ratio of
performance and noise level). The project will be powered by a single
cell LiPo battery. If I understand the datasheets (e.g. TI lmr62014) of
some of the lower cost step up converters correctly the Vout will be
depending on Vin, so Vout will be higher when the LiPo cell is at 4.2
than at around 3.7V. Is this correct and are there alternatives that
keep Vout stable even if the LiPo voltage drops?
Also, can I use a step-up converter's enable/shutdown pin to switch on /
off my DC motor or do I need to switch load with a separate transistor /
fet after the converter is started up?
Thanks for your help!
Jens
von Peter (Guest)
All DC/DC converters (I am aware of) regulate the output voltage.  The
LMR62014 definitely does.
As you can see in the connection diagram on page 2 of the LMR62014 data
sheet, the output remains connected to the input via L1 and D1 even if
the converter is in shutdown. So you will need a separate FET.
von Andreas (Guest)
Jens, du könntest auch auf der deutschen Seite (hier), direkt auf
deutsch schreiben.
von Andreas (Guest)
Hi Peter,
thanks for the swift reply and good advice! Any step up converter that
doesn't require external diode & fet that you would recommend (<=70 cent
/1000u)?
@Andreas: Danke für den Tip!
Gruß,
Jens
