Forum: FPGA, VHDL & Verilog Please Help! Not gate implementation nand
von Mihai M. (mike999)
Hello everybody! I need some help. I use VHDL language and ModelSim PE
Student Edition. I nade to build some elementary gates: not, or, xor,
and, mux mux, dmux, 16 bit variants not16 and16 and multiway variants
mux8way16 etc from nand gates. I made some schematics on paper and
logic. Ex. Not imp. Nand : (a Nand b) Nand (a Nand b).
My first gate i want to buils is Not gate. (a nand a), for this i make
this code:
library IEEE;
use ieee.std_logic_1164.all;
entity noot is
         port (a : in std_logic;
               cout : out std_logic
end noot;
architecture behavior of noot is
          component naand
           port(
                a1 : in std_logic;
                b1 : in std_logic;
          end component;
     NA1 : naand port map (
                a1 =>a,
                b1 =>a,
                out1 => cout
so here is my problem, how i can do the function of nand?
it was simple to write:
 cout<= a nand a;
but i want later to add more nand gates in separate bloks
i try with signal
signal s1, s2 : std_logic := '0'; or without ":= '0'"
                a1 =>s1,
                b1 =>s2,
                out1 => cout => s1 nand s2
How i can make this to work?
This is schematic of wat i want:
                        NOT GATE
            ____________________________
           |            ________        |
           |      _____|        \       |
    a      |     /     |         \      |  cout
-----------|----=      |   NAND   |-----|-------
           |     \_____|         /      |
           |           |________/       |
           |____________________________|
: Edited by Moderator
Mihai M. wrote:
> I use VHDL language
Pls have a look at the screenshot...
> component naand
That component has no output. Its useless and will be optimized away.
What should this do?
In a port map you ca assign 1 port to 1 signal.
I'm not able to figure out your problem... :-/
Try it this way and think about it...
library IEEE;
entity naand is
         port (a1,b1 : in std_logic;
               out1 : out std_logic);
end noot;
architecture behavior of naand is
begin
    out1 <= a1 nand b1;
end behavior;
library IEEE;
entity noot is
end noot;
     component naand
     end component;
30
31
32
                a1 => a,
33
                b1 => a,
34
                out1 => cout
35
36
end behavior;
Well,  i want to make that component naand to function like a nand gate,
thx for the information.
