Forum: FPGA, VHDL & Verilog Help with code for SPGA
Author: Vadhiraj (Guest)
I need a code to generate 4 different pulse signals, at same time. all
are at frequency of 50Hz.
1st one starts after a delay of 0.01sec and ends at 0.011 sec.
2st one starts after a delay of 0.005sec and ends at 0.008 sec.
3st one starts after a delay of 0.01sec and ends at 0.015 sec.
4st one starts after a delay of 0.004sec and ends at 0.01 sec.
can any one help with the code.
all these signals are independent of each other. and have to be
pulsating always.
Author: Vancouver (Guest)
FPGA, I think?
Obviously you need a resolution of 1ms. Write a 5-bit counter that ist
clocked at 1kHz. The first output is set to 1 between counter=10 and
counter=11 and 0 else. The second output is set 1 between counter=5 and
counter=8 and 0 else, etc. The counter is reset after counter=19, since
your period is 20ms.
Which code?
First you must generate a "timertic" of 1ms.
Then you take a pattern of each timing:
signal_1 = "00000000001000000000"
signal_2 = "00000111000000000000"
signal_3 = "00000000001111100000"
signal_4 = "00001111110000000000"
With that you can simply run through those pattern with an index that is
reset each 20ms.
> I need a code
No one here will do your homework. So you start with something and
then we discuss the problems (if there are any).
> I need a code
Which language, what target and toolchain?
I could write that in C, Basic, VHDL and some more, but not in Verilog.
So its essential neccessary to know your target.
  • [vhdl]VHDL code[/vhdl]
