Forum: FPGA, VHDL & Verilog counting length of input signal in clock cycle units
Author: Counting length of input signal (Guest)
Hello everyone!
My task is to write an up counter, that counts how long is the input
signal (in) in clock (clk) cycle units from 1 to 1023 (precision 1 clock
cycle). When input signal (in) ends, there has to be signal on wire
ready, which means that data are ready to read and the value from the
counter is now avaliable on data output. This value stays there until
the end of the next input signal.
The whole project consists of 3 sequential processes: falling edge
detector, counter and output register.
It has to be module with synchronous clock and asynchronous reset.
My problem here is that I don't reset the counter when input signal
ends.
As an attachment I am posting my code for module and test bench.
X.
Author: Andi (Guest)
Your problem is that the counter is free running, and not only when the
input pulse is high.
Eighter you make a pos-edge detector (in the same manner as the
neg-edge) and reset the counter if the positive edge is detected.
Or you reset the counter while the ready signal is present and you
enable the count up only if the pulse is high:
  if (ready) begin
    on_out <= count;
    counter <= 10'b0;
  end
for that you need to have the counter code and the ready code in the
same always() block, you can not write to counter in two different
blocks.
BTW: The following is useless, the counter anyway rolls over from
1111111111 to 0000000000:
  if(count == 10'b1111111111)
    count <= 10'b0;
It would make more sense to stop the counter on all ones, so a too long
pulse will always show the longest possible time.
Andi
  • [vhdl]VHDL code[/vhdl]
