Forum: FPGA, VHDL & Verilog Does Verilog have generic map like VHDL?
Author: Sean Zheng (Guest)
I am a beginner of Verilog. I am trying to build an N-bit-comparator.
But I found no information for any generic map. I know in VHDL I can do
generic (N: integer:=4);
so that I can modify bits when I want to use this block.
If there is anything in Verilog that is similar to generic map in VHDL,
it will help save me lots of work.
Author: Tim (Guest)
googled: verilog generic
http://www.asic-world.com/verilog/para_modules1.html
sufficient explaination for you?
Author: Lattice User (Guest)
It is called parameter
module Sample #(parameter Width=8) (input wire [Width-1:0] DataIn)
Instanziated it is like this:
wire [11:0] Data;
Sample #(.Width(12)) InstanceName (.DataIn( Data ));
Thank you! My problem's solved now!
@Lattice, Thank you! Now I understand very clear!
  • [vhdl]VHDL code[/vhdl]
