Forum: FPGA, VHDL & Verilog looking for 16 bits adder in vhdl
Author: Maxim Moor (max_min)
i need a vhdl code to add 16  bits registers
Author: Klaus (Guest)
Most synthesizers will instantiate adder structures if you write:
library ieee;
use ieee.numeric_std.all;
signal a: unsigned(8 downto 0); 0 to 2**9-1
signal b: unsigned(7 downto 0); 0 to 2**8-1
a <= b + c;
Note, that the signal a, holding the result, must be one bit wider than
the signals holding operands.
Consider - which means read about - using the packages numeric_std (in
contrast to std_logic_vector).
In case you want to see explicit code of an adder, search the internet.
I am not sure, but I assume that somebody posted such code just for
educational purposes.
  • [vhdl]VHDL code[/vhdl]
