Forum: FPGA, VHDL & Verilog VHDL basic computer sequential implementation
von Maxim M. (max_min)
I am working now on implementing a 16 bit RISC CPU in VHDL, the
instruction set consists of 8 instructions 16 bits each.
the architecture of the data path and instruction flow is here, i need
your help how to start implementation? could you give me examples for
source codes like this architectur
von S. N. (higgns)
All I can say is that you should try to make a feature list and some
test cases for each submodule to make yourself clear what you should
implement and then go on from there...
There are hundreds of custom CPUs on the net you just have to search a
bit. I found this PDF very helpful:
http://opencores.org/usercontent,doc,1262702554
