Forum: FPGA, VHDL & Verilog RE: I was wondering where I went wrong
von Joseph J. (earthkid123)
module display (clock, AN0, AN1, AN2, AN3, CA, CB, CC, CD, CE, CF, CG, CDP);
//USED FOR SEVEN SEG
input clock;
output AN0, AN1, AN2, AN3, CA, CB, CC, CD, CE, CF, CG, CDP;
reg [7:0] cathodedata; //cathode data
reg [3:0] anodedata; //anode data
reg [2:0] digit = 1;
reg [6:0] data;
reg setdp;
reg [19:0] counter = 0;
assign CA = cathodedata [7];
assign CB = cathodedata [6];
assign CC = cathodedata [5];
assign CD = cathodedata [4];
assign CE = cathodedata [3];
assign CF = cathodedata [2];
assign CG = cathodedata [1];
assign CDP = cathodedata [0];
assign AN3 = anodedata [3];
assign AN2 = anodedata [2];
assign AN1 = anodedata [1];
assign AN0 = anodedata [0];
30
    //Multiplexing
31
    //Board Clock: 50MHz
32
    //p = t*f
33
    //t = 16ms
34
    //p = 16ms * 50*10^6 = 800,000 cycles
35
    //200,000 cycles for each digit
36
    //Refreshed every 16ms (~60Hz)
37
38
always@(negedge clock)
39
begin
40
    if (digit == 1)
41
        begin
42
            if (counter == 200000)
43
                begin
44
                    digit = 2;
45
                end
46
            else
47
                begin
48
                counter = counter + 1;
49
                data = 4;
50
                end
51
        end
52
    else if (digit == 2)
53
        begin
54
            if (counter == 400000)
55
                begin
56
                    digit = 3;
57
                end
58
            else
59
                begin
60
61
                    data = 3;
62
                end
63
        end
64
    else if (digit == 3)
65
        begin
66
            if (counter == 600000)
67
                begin
68
                    digit = 4;
69
                end
70
            else
71
                begin
72
73
                    data = 2;
74
                end
75
        end
76
    else if (digit == 4)
77
        begin
78
            if (counter == 800000)
79
                begin
80
                    digit = 1;
81
                    counter = 0;
82
                end
83
            else
84
                begin
85
86
                    data = 1;
87
                end
88
        end
89
end
90
91
92
always @ (*)
93
begin
94
95
    case (data)
96
        6'd0: cathodedata = 8'b00000011; //0
97
        6'd1: cathodedata = 8'b10011111; //1
98
        6'd2: cathodedata = 8'b00100101; //2
99
        6'd3: cathodedata = 8'b00001101; //3
100
        6'd4: cathodedata = 8'b10011001; //4
101
        6'd5: cathodedata = 8'b01001001; //5
102
        6'd6: cathodedata = 8'b01000001; //6
103
        6'd7: cathodedata = 8'b00011111; //7
104
        6'd8: cathodedata = 8'b00000001; //8
105
        6'd9: cathodedata = 8'b00001001; //9
106
        6'd10: cathodedata = 8'b00010001; //A
107
        6'd11: cathodedata = 8'b11000001; //B
108
        6'd12: cathodedata = 8'b01100011; //C
109
        6'd13: cathodedata = 8'b10000101; //D
110
        6'd14: cathodedata = 8'b00100001; //E
111
        6'd15: cathodedata = 8'b01110001; //F
112
        default: cathodedata = 8'b11111111; //default all off
113
    endcase
114
115
    if (setdp == 1) //decimal point
116
        cathodedata = cathodedata & 8'hFE;
117
118
    case(digit)
119
        0: anodedata = 4'b1111; //all OFF
120
        4: anodedata = 4'b1110; //AN0
121
        3: anodedata = 4'b1101; //AN1
122
        2: anodedata = 4'b1011; //AN2
123
        1: anodedata = 4'b0111; //AN3
124
        default:
125
126
    endcase
127
128
end
129
endmodule
I am using a Nexys 2 digilent board with Xilinix and I just want to turn
the seven seg display on as a countdown
: Edited by User
I was wondering in the code what the anode data would be in order to get
the lights to turn on I am so very confused
module seven_seg( intput [3:0]numbers, output reg[6:0] display);
always @(numbers)
  begin
    case(numbers)
      4'h0: out1=7'b1000000;  //0111111;
      4'h1:  out1=7'b1111001;  //0000110;
      4'h2:  out1=7'b0100100;  //1011011;
      4'h3: out1=7'b0110000;  //1001111;
      4'h4: out1=7'b0011001;  //1100110;
      4'h5: out1=7'b0010010;  //1101101;
      4'h6: out1=7'b0000010;  //1111101;
      4'h7: out1=7'b1111000;  //0000111;
      4'h8: out1=7'b0000000;  //1111111;
      4'h9: out1=7'b0011000;  //1100111;
       default: out1=7'b1111111;//0000000;
    endcase
  end
endmodule
endmodule
// display numbers*/
module Slowclock(input wire clk, output reg clkslowed
  integer count=0;
  always @(posedge clk)
    begin
      if(count<12500)
      begin
        count=count+1;
      end
      else
      begin
            clkslowed=!clkslowed;
            count=0;
          end
      end
endmodule
//slow down clock speed so you can manipulate the seven seg display */
I just dont know why my lights arent going on I have the nexys 2 board I
need the countdown to work or seven seg display I need for it to
countdown from 9 to 0
Joseph J. wrote:
> I just want to turn the seven seg display on as a countdown
What did happen instead?
And how did you find that out?
You don't have to start a new THREAD for each post. You can simply
append new experiences with the edit box at the end oo the thread...
: Edited by Moderator
von Joseph (Guest)
> And how did you find out
 Nothing happened it didn't turn on at all the seven segment. I found
because it didn't work I don't know where I put the actual lights part
referenced as A0 in the next part.
von Joseph Abel (Guest)
I feel like im messing my user constraints file I am not sure
What does your simulation look like?
In a behavioral simulation no UCF file is involved. And therefore its
the best way to start that way.
> I am not sure
What about trying to switch on just some segments on one of the
digits. That would be a wholy static design without counters and other
more tricky things.
So: do some small steps and learn by those small steps...
von Joseph (Guest)
I simulated it and I still don't see my problem im not sure what the
error is why my seven segment display isnt working
Joseph wrote:
> I simulated it
With what result?
Does the behavioral simulation work as expected?
Then something with the implementation on the hardware is wrong. And the
most significant part to interact with the toolchain is the ucf file.
There the pin constraints are most important...
