Forum: FPGA, VHDL & Verilog Error: Range expressions could not be resolved to constant
von Rohan Narkhede (Guest)
Hi all,
I get an error as : Range expressions could not be resolved to constant
in the for loop:
for i in nshft-1 downto 0 loop
where - signal nshft : integer range 32 downto 1;
Is it because that I am assigning an integer with a range limit to a
constant iterator in for loop? In that case what would be the solution?
Please see the code and screenshot attached.
Thanks and regards,
Rohan Narkhede
Rohan Narkhede wrote in post #4372153:
"Range" in this error message is the loop range "nshft-1 downto 0".
A for-loop in VHDL is only allowed with constant values for synthesis.
Obviously nshift is not a constant value...
Look at the barrel shifter in https://embdev.net/topic/346009
BTW: Only one thread with the same question pls.
: Edited by Moderator
