Forum: FPGA, VHDL & Verilog Asynchronous / synchronous reset
von Alex R. (Company: None) (rybin87)
What is the difference between these?
First: the name!
Second: the sync reset needs a (continous) clock to reset the actual
value of a flipflop, the async reset resets a flipflop immediately.
Third: why do you ask? Whats the actual problem?
Thank you, Lothar. So the sync reset will wait for a clock signal, then
it will reset a device, and the other does it at once. Am I right?
Here is the problem as a whole. I'm trying to use a Matlab-generated FIR
filter. It runs on higher speed, then the main clock, and it's higher
speed is generated by PLL. That is because the filter is made 20x serial
to reduce the number of multipliers on a rather small EP4CE6. The data
won't feed correctly into it.
And how does this relate to sync or async resets?
Any figure for that "high speed"?
For me it seems like a simple constraint or clock-domain-crossing
problem. Or the FPGA is simply to slow to handle the speed...
> The data won't feed correctly into it.
But the simulation runs fine?
von out of the mist (Guest)
No, not at all. Nothing waits for the clock, the clock triggers
everything. The asynchrounous reset does nothing at once, it takes some
nanosecs for the FF and sometimes longer than setup and clock to output
time as for the synchrous reset.
Is somebody familiar with Matlab HDL filters logic? They have reset and
clock enable inputs.
How to initialize the filter properly?
That's what I need to know to imagine timing diagram for the device.
Maybe, this needs to be explored.
Unfortunately, I test just "in vivo" so far.
I don't quite follow you. Of course a small amount of time is necessary
for this.
: Edited by User
