Forum: FPGA, VHDL & Verilog Error: found '0' definitions of operator "<=", cannot determine exact overloaded matching definition
von Rohan Narkhede (Guest)
Hi all,
I created a code for shift register using Melay FSM. The shift register
is programmed such that it has states like Arithmatic, Logic shifts as
well as Barrel Shifter and also it acts like normal register to store
the data. The code file and test bench are attached.
While compiling, I get an error : "found '0' definitions of operator
"<=", cannot determine exact overloaded matching definition for "<=" ",
in test bench code at line 89 (see screenshot). I do not understand why
this error is occuring. Please let me know how can I remove this error.
Thanks and regards,
Rohan Narkhede
von Guest (Guest)
There is a comma instead of a semicolon at the end of the previous line.
