Forum: FPGA, VHDL & Verilog NIOS II Flash Programmer
von Gilian (Guest)
Hallo all,
I am trying to program and configure the HW (time_limited.sof file)
using the Quartus Programmer and to generate and flash the SW (.ELF)
using the Flash Programmer.
Unfortunately I am facing an error for which I could find no solution.
Below is the error:
Info: Using cable "USB-Blaster [USB-1]", device 1, instance 0x00
Info: Resetting and pausing target processor: FAILED
Info: Leaving target processor paused
Error: Error code: 4 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "C:/Dev/APP/src/FPGA/Project/flash/Dev_App_external_flash.flash" --base=0x0 --sidp=0xA404F00 --id=0x0 --accept-bad-sysid --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-1]' --program --verbose
Also, I checked on my QSys component connections which looks alright.
Has anyone faced this problem before and found a solution?
von toni (Guest)
restart jtagserver
