Forum: FPGA, VHDL & Verilog Variable memory generation
von Priya S. (priya_022)
Hi, In verilog is it possible to create Variable memory ? Please,help me
with solution.
 Please see the below Example code in the attachments
After running the code (In the attachments), i got the below error
ERROR:HDLCompiler:44 -
"D:\Xilinx_Codes\Final_FE_and_BD_Synthesis_XILINX\Box_Counting\Box_Count
ing\box_count.v"  Line 137: append_max is not a constant
ERROR:HDLCompiler:598 -
ing\box_count.v"  Line 21: Module <box_count> ignored due to previous
errors.
In the code. "append_max" is the variable which changes based on its
dependable variables.
Thanks in advance.
von Lattice User (Guest)
> with solution.
This is not possible, and the error message clearly states it.
Hi Lattice, Thank you very much for your kind response.
