Forum: FPGA, VHDL & Verilog There are no HDL sources in file set 'sources_1'. Please use the Add Sources command.
von Rohan Narkhede (Guest)
I am getting an error : There are no HDL sources in file set
The code file and the error screenshot are attached. Please let me know
what could be the cause of error and how to remove it.
Thanks and regards,
Rohan Narkhede
Just to add, I am using Xilinx Vivado for code compilation.
von Rainer (Guest)
The screenshot shows syntax error. You have to fix them first.
von Rainer (Guest)
What does vivado complain about. If you click on the "syntax error
files" you should see in which line your problem is.
The syntax error it shows is at line 42 and 44. (Please see the new
screenshot attached with this reply). I don't understand what is the
syntax error here, as I have ended the process and ended the
architecture - reg_arch like normal syntax.
Thanks an dregards,
Rohan Narkhede
von derLars (Guest)
There is an "end if;" missing right in front of end process!
Thank you so much derLars!!
von derLars (Guest)
If you use tabs consequently, it is very easy to observe, like:
entity reg is
  port(
    clk     : in  std_logic;
    reset   : in  std_logic
end entity reg;
architecture reg_arch of reg is
  signal r_reg : std_logic_vector(1 downto 0);
begin
  process(clk)
  begin
    if reset = '1' then
    elsif rising_edge(clk) then
      if ctrl0 = '0' ... then
      elsif ...
      elsif ...
      end if;
      <<<<<<<<<<<<<<<<<<< here is something obviously missing!
  end process;
  dout <= r_reg;
30
end architecture;
