Forum: ARM programming with GCC/GNU tools Suppressing the GCC warning: "<term1> is obsolescent, use <term2> instead."
von Magentus _. (magentus)
I've been programming in C++ for years, but I am new to programming on
Linux and gcc/g++. My team at work is developing an application for
embedded Linux. We want to be able to build our code without any
compiler or linker warnings, in order to use the '-Werror' flag.  That
way we would enforce fixing causes on any new warnings as and when they
are introduced.
Our problem is caused by third party libraries. I've managed to suppress
compiler warnings relating to code in Boost etc, by using '-isystem'
instead of '-I'. Warnings that remain seem to be caused by the linker.
We get a number of these:
[...]/usr/lib/libcrypto.so: warning: gethostbyname is obsolescent, use
getnameinfo() instead.
Using '-Wno-deprecated-declarations' doesn't have the desired effect.
Is there a way to suppress the '<term> is obsolescent' warning generated
for code in third party libraries?
Thanks.
von Rolf Magnus (Guest)
That's because that warning is not about a declaration, and actually not
even coming from GCC, but from the linker.
I don't know any way to switch this off.
That makes sense.
Thank you.
von Guest (Guest)
If the linker is the source of the problem you can try building the SW
by first compiling to object code (with the -Werror flag) then linking
(without the -Werror flag).
In theory we could, but it would be impractical. The goal here is to set
the '-Werror' flag on, which then enforces the policy of not introducing
new warnings.
Doing it in the proposed two-step process would put the onus of
following it on the developer, and that is the situation in which our
team already is.  Seeing as new warnings still creep in, some of our 10+
developers clearly can't handle that responsibility.
I appreciate you suggesting it, though.
von Guest (Guest)
If you can enforce setting the -Werror flag for the complete build, I
see no reason why you couldn't do that only for the compile stage. This
way you catch only the warnings that your developers add, not the ones
dragged in by the libraries.
By using the pre commit hooks that your revision control system you can
even deny any commit that produces warnings.
Putting suitable processes in place and enforcing them would also help.
von Nase (Guest)
What about actually fixing the third-party library...?
The symbol is flagged obsolete for a reason.
> team already is.
Huh? Why?
@Guest (Guest):
Thank you for pointing that out!  From the start I (incorrectly) assumed
that '-Werror' would affect linker warnings as well as compiler ones.  I
tried adding the flag to ...CXX_FLAGS and it works! Thanks again.
@Nase:
I thought of that, too, but it's not an option at this point for various
reasons.
@Rolf Magnus:
My point was that seeing as there was no '-Werror' which would force
developers to fix all new warnings before committing their changes, we
were already in a situation where it's (or at least it should be) each
developer's responsibility to personally ensure no new warnings are
introduced.  And yet, some of them still weren't doing it.  Now they'll
have to.
Thank you all!
