Forum: FPGA, VHDL & Verilog No feasible entries for infix operator "="
Author: VHDL New user (darylczj1995)
Hi all! i am new to VHDL and i was ask to write a program in VHDL to
implement a 3-input sequential Poller. The Poller has three inputs
representing three devices. A device request service by asserting its
input. On every clock cycle, the polling machine checks the status of
the three input devices and generates an output code that identifies the
asserted input(device) to be serviced, the device with the highest
priority is selected. Each input is assigned a fixed priority denoted by
its subscript; 3 is the highest priority and 1 is the lowest priority.
To prevent "starving" the lower devices, the same asserted input is
never selected on two successive pollings unless there are no other
asserted pins.
    library ieee;
    use ieee.std_logic_1164.all;
    entity poller is port
      req        : in std_logic_vector(3 downto 1):="000";
      clk,nreset : in std_logic_vector;
      ack        : out std_logic_vector(1 downto 0)
    end poller;
    architecture behave of poller is
    type states is (none,req1,req2,req3);
      signal state : states;
    begin
     moore : process(clk, nreset)
     begin
      if(nreset = '1') then
       state <=none;
      elsif(clk' event and clk = '1')then
     case state is
     when none =>
                  if req(3)= '1' then
                    state <= req3;
                  elsif req(2)='1' then
                    state <= req2;
                  elsif req(1)='1' then
                    state <= req1;
                  end if;
      when req1 =>
                  if req(3)= '1' then
                    state <= req3;
                    state <= req2;
                    state <= req1;
                  else
                    state <= none;
                  end if;
      when req2 =>
                  if req(3)='1' and req(2)='0' and req(1)='0' then
                    state <= req3;
                  elsif req(3)='1' and req(2)='1' and req(1)='0' then
                    state <= req3;
                  elsif req(3)='1' and req(2)='0' and req(1)='1' then
                    state <= req3;
                  elsif req(3)='0' and req(2)='1' and req(1)='0' then
                    state <= req2;
                  elsif req(3)='0' and req(2)='0' and req(1)='1' then
                    state <= req1;
                  else
                    state <= none;
                  end if;
      when req3 =>
                    state <= req3;
                    state <= req2;
                    state <= req1;
                    state <= req2;
                  elsif req(3)='0' and req(2)='1' and req(1)='1' then
                    state <= req2;
                    state <= req1;
                  else
                    state <= none;
                  end if;
                end case;
              end if;
            end process;
      ack <= "00" when (state= none)
    else "01" when (state= req1)
    else "10" when (state= req2)
    else "11";
    end behave;
While compiling the code in Modelsim PE Student I get the following
error
    ** Error: C:/Users/work/h/vhdl/poller.vhd(24): No feasible entries
for infix operator "=".
    ** Error: C:/Users/work/h/vhdl/poller.vhd(24): **Type error
resolving infix expression "=" as type std.STANDARD.BOOLEAN.**
    ** Error: C:/Users/work/h/vhdl/poller.vhd(27): No feasible entries
    ** Error: C:/Users/work/h/vhdl/poller.vhd(27): Bad expression in
right operand of infix expression "and".
    ** Error: C:/Users/work/h/vhdl/poller.vhd(27): Type error resolving
infix expression "and" as type std.STANDARD.BOOLEAN.
    ** Error: C:/Users/work/h/vhdl/poller.vhd(91): VHDL Compiler exiting
Any help is appreicated:)
: Edited by Moderator
i found a solution to it
instead of
library ieee;
end poller;
it is
library ieee;
  clk,nreset : in std_logic;
end poller;
i made a mistake at my entity.
  • [vhdl]VHDL code[/vhdl]
