Forum: FPGA, VHDL & Verilog Multiplexer Help
von john Wilson (Guest)
Im trying to implement a generic Mux on the spartan 3e using Xilinx ISE.
I am having issues with this,
I have an input, call it INPUT_A that can be Q bits wide and a select,
SEL_B that is R bits wide. output is 3 bits
In the entity its like this:
generic R=2, Q=3
INPUT_A is a std_logic_vector (2**R)*Q downto 0);
SEL_B std_logic_vector (R-1 down to 0);
output std_logic_vector(Q downto 0);
I have the entity OK, but just cant get the device itself.
i have something like this for the actual device in one line:
output<INPUT_A((conv_integer(SEL_B)+1)*Q-1 downto conv_integer(SEL_B)*Q)
Can anyone give any ideas on this?
Thank you
von P. K. (pek)
What is exatly your problem? This does not look so bad. Use correct
assignments and type castings. The following line works perfectly for me
(and may suit as  a starting point to you):
library ieee;
use ieee.STD_LOGIC_1164.all;
use ieee.numeric_std.all;
OutxD <= InxDI(10*pNr+ 9 downto 10*pNr);
where pNr is an integer, range limited to InxDI, all others are of type
unsigned.
: Edited by User
P. K. wrote:
> Use correct assignments and type castings.
And pls. do not use those use IEEE.STD_LOGIC_ARITH and
IEEE.STD_LOGIC_UNSIGNED from the last millenium.
Use the numeric_std instead. It is straightforward and simple. Try that
with Google translator (its German):
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
: Edited by Moderator
von John Wilson (Guest)
Hi guys,
thanks for your replies.
Ive begun writing a test bench to test this.
Just a standard testbench without any error outputs to check the
waveform when I simulate.
I'm having trouble trying to implement a testbench however.
I'm thinking I need two loops to test all possible inputs as the output
relies on select?
any ideas on how to generic testbench this?
thanks guys
I wanted to know if anyone had some experience designing a testbench,
for a generic multiplexer.
Select is M
the input is generic N
Im more concerned with the loop to make the testbench UUT go through all
the possible combinations to confirm the correct otuputs?
any help guys
thanks
John Wilson wrote:
> Select is M
How do they relate to each other?
Show the code or at least the port definition of that multiplexer. There
must be at least 3 signals to see: input(s), select and output
And pls: do not start every other day an new thread for the very same
question! I concatenated them as they relate the same topic...
Hi Lothar,
Thanks for the reply,
The code for the implementation is below, the synthesizer gives a
warning for the implementation but its not the main issues. Its just im
not sure how to do the testbench for a generic mux?
entity MUX is
GENERIC(N: INTEGER := 3;
        M: INTEGER := 2);
    Port ( myin : in  STD_LOGIC_VECTOR((2**M)*N-1 downto 0);
           myout : out  STD_LOGIC_VECTOR(N-1 downto 0);
           sel : in  STD_LOGIC_VECTOR (M-1 downto 0));
end MUX;
architecture Behavioral of MUX is
begin
--mux_proc:process(myin,sel)
--variable intnewsel:= conv_integer(sel);
--begin
myout<=myin((conv_integer(sel)+1)*N-1 downto conv_integer(sel)*N);
--end process;
end Behavioral;
ENTITY GENERIC_MUX_UUT IS
END GENERIC_MUX_UUT;
30
31
ARCHITECTURE behavior OF GENERIC_MUX_UUT IS
32
33
    -- Component Declaration for the Unit Under Test (UUT)
34
35
    COMPONENT MUX
36
    PORT(
37
         myin : IN  std_logic_vector((2**M)*N-1 downto 0);
38
         myout : OUT  std_logic_vector(N-1 downto 0);
39
         sel : IN  std_logic_vector(M-1 downto 0)
40
41
    END COMPONENT;
42
43
44
   --Inputs
45
   signal TX_in : std_logic_vector((2**M)*N-1 downto 0) := (others => '0');
46
   signal TX_sel : std_logic_vector(M-1 downto 0) := (others => '0');
47
48
   --Outputs
49
   signal TX_out : std_logic_vector(N-1 downto 0);
50
51
52
53
54
BEGIN
55
56
  -- Instantiate the Unit Under Test (UUT)
57
   uut: MUX PORT MAP (
58
          myin => TX_in,
59
          myout => TX_out,
60
          sel => TX_sel
61
62
63
   -- Clock process definitions
64
65
66
   -- Stimulus process
67
   MUX_UUT: process
68
  variable vmyout:std_logic_vector (N-1 downto 0);
69
   begin
70
   for i in 0 to 2**M LOOP
71
    vmyout := Tx_in(i);
72
    wait for 100 ns;
73
74
End Loop;
75
    -- hold reset state for 100 ns.
76
77
78
79
      -- insert stimulus here
80
81
      wait;
82
   end process;
83
myout<=vmyout;
84
END;
First: READ THE MANUAL.
And the manual for the editbox here ist just a few lines above:
    [vhdl]VHDL code[/vhdl]
John Wilson wrote:
> The code for the implementation is below ...
> entity MUX is
Did you know: each VHDL code sarts well before the keyword "entity".
All of mine start with "library"...
> conv_integer
A lttle reminder: https://embdev.net/topic/377905?goto=4300680#4292803
> myout <= vmyout;
You cannot assign a value to an output. Have a closer look to the
signals direction, it was you giving them that names...
> vmyout := Tx_in(i);
> myout <= vmyout;
A little poking around in the dark?
1. You do not need a variable here...
2. Why do you read a value from a port, where you should hand over a
input value, and write it to a port, where an output is assigned by
the UUT?
To keep things subtantially short: have a very close look at my
design...
Hi Lothar,
Thank you very much for your help, I really appreciate it.
I was as you rightly guessed poking in the dark  in some places.
Ive looked over your code and it makes a lot of sense.
i did try running  a simulation, it passes the behavioral check without
issues, the muxout however doesn't generate the result you got from your
simulation.
thank you
> simulation.
What instead?
Did you use exactly my code?
Can you show a screenshot of your simulations waveform?
What simulator did you use? (Mine was ISIM from ISE14.2)
von Rukhsana (Guest)
Oi murilo, em geral he1 2  cinomhas  pra seguir na busca por reduzir o
espae7o ocupado pelo cf3digo no FPGA:1) Regular as configurae7f5es da
tua ferramenta de sedntese (ISE, Quartus, etc). Vocea pode tentar
aumentar o nedvel de otimizae7e3o pra espae7o (vai aumentar bastante seu
tempo de sedntese), pode tentar mudar a codificae7e3o das suas me1quinas
de estados (usar menos bits), ou ente3o pode tentar colocar o
armazenamento em BRAMs ao inve9s de em flip-flops (tem uma
configurae7e3o no ISE pra isso, mas eu ne3o me lembro onde).2) Diminuir
o paralelismo no seu design: Essa alternativa je1 e9 mais difedcil, mas
vai resultar numa mudane7a maior no espae7o ocupado no FPGA. O objetivo
e9 vocea tentar localizar blocos no seu cf3digo VHDL em que operae7f5es
se3o feitas em paralelo, ou seja, em que he1 replicae7e3o de hardware.
Daed vocea deve tentar serializar essas operae7f5es, usando por exemplo
uma me1quina de estados para controlar a sequeancia.  No exemplo do
somador do post, a gente poderia ter usado apenas UM FULL-ADDER de 1
bit, ao inve9s de N. Isso iria diminuir o espae7o ocupado na FPGA.Espero
ter te ajudado um pouco, e ne3o confundido mais :)
