Forum: ARM programming with GCC/GNU tools i want to map in0 to out0
von aadhii88 (Guest)
#include "stm32f0xx.h"
#include "stm32f0308_Discovery.h"
#define in0 GPIO_Pin_0
#define in1 GPIO_Pin_1
#define in2 GPIO_Pin_2
#define in3 GPIO_Pin_3
#define in4 GPIO_Pin_4
#define in5 GPIO_Pin_5
#define in_GPIO GPIOA
#define out0 GPIO_Pin_1
#define out1 GPIO_Pin_1
#define out2 GPIO_Pin_2
#define out3 GPIO_Pin_3
#define out4 GPIO_Pin_4
#define out5 GPIO_Pin_5
#define out_GPIO GPIOC
void TM_Delay_Init(void);
void TM_DelayMillis(uint32_t millis);
void TM_DelayMillis1(uint32_t millis);
void TM_DelayMillis2(uint32_t millis);
GPIO_InitTypeDef       GPIO_InitStructure ;
uint32_t multiplier;
int main(void)
          SystemInit();
          SystemCoreClockUpdate();
          TM_Delay_Init();
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
    /* Configure PA in input mode */
      GPIO_InitStructure.GPIO_Pin =
((GPIO_Pin_0)|(GPIO_Pin_1)|(GPIO_Pin_2)|(GPIO_Pin_3)|(GPIO_Pin_4)|(GPIO_
Pin_5))  ;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
      GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;              //
enable internal Pullup resistors on the GPIO pins
      GPIO_Init(GPIOA, &GPIO_InitStructure);
  /*configure PC in output mode */
  GPIOC->MODER  |=
((GPIO_MODER_MODER0_0)|(GPIO_MODER_MODER1_0)|(GPIO_MODER_MODER2_0)|(GPIO
_MODER_MODER3_0)|(GPIO_MODER_MODER4_0)|(GPIO_MODER_MODER5_0))  ;
  //GPIOC-> GPIO_MODER_MODER8_0 = 0x01;
  GPIOC->OTYPER &=
~((GPIO_OTYPER_OT_0)|(GPIO_OTYPER_OT_1)|(GPIO_OTYPER_OT_2)|(GPIO_OTYPER_
OT_3)|(GPIO_OTYPER_OT_4)|(GPIO_OTYPER_OT_5))  ;
  //GPIOC->OTYPER = 0x00;
  GPIOC->OSPEEDR |=
((GPIO_OSPEEDER_OSPEEDR0)|(GPIO_OSPEEDER_OSPEEDR1)|(GPIO_OSPEEDER_OSPEED
R2)|(GPIO_OSPEEDER_OSPEEDR3)|(GPIO_OSPEEDER_OSPEEDR4)|(GPIO_OSPEEDER_OSP
EEDR5));
  //GPIOC->OSPEEDR = 0x00;
  GPIOC->PUPDR &=
~((GPIO_PUPDR_PUPDR0)|(GPIO_PUPDR_PUPDR1)|(GPIO_PUPDR_PUPDR2)|(GPIO_PUPD
R_PUPDR3)|(GPIO_PUPDR_PUPDR4)|(GPIO_PUPDR_PUPDR5));
  while(1)
    if(GPIO_ReadInputDataBit(GPIOA, (GPIO_Pin_0|1|2|3|4|5==1)))
      GPIO_SetBits(out_GPIO,(out0)|(out1)|(out2)|(out3)|(out4)|(out5));
        TM_DelayMillis(7);
        GPIO_ResetBits(out_GPIO,(out0)|(out1)|(out2)|(out3)|(out4)|(out5));
      while (GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0|1|2|3|4|5)==1)
          TM_DelayMillis1(3);
          TM_DelayMillis2(22);
void TM_DelayMillis(uint32_t millis) {
    /* Multiply millis with multipler */
    /* Substract 10 */
    millis = 100  millis  multiplier - 10;
    /* 4 cycles for one loop */
    while (millis--);
void TM_DelayMillis1(uint32_t millis) {
    /* Substract 10 */
    millis = 1  millis  multiplier - 10;
    while (millis--);
void TM_DelayMillis2(uint32_t millis) {
    /* Substract 10 */
    while (millis--);
void TM_Delay_Init(void) {
    RCC_ClocksTypeDef RCC_Clocks;
    /* Get system clocks */
    RCC_GetClocksFreq(&RCC_Clocks);
    /* While loop takes 4 cycles */
    /* For 1 us delay, we need to divide with 4M */
    multiplier = RCC_Clocks.HCLK_Frequency / 4000000;
NOTE:in this i have to make only one pin high if i make high that pin
i.e when in press in0 only out0 should be high all other pins should be
low vice versa
von kbuchegg (Guest)
Äghm
No. That does not work that way.
I recommend a C Book before starting any serious programming work
thank you sir.i will do the same as you said.
kindly guide me how to make one input and one output high(mapping) and
all the other pins to be low.
when i give one input relevant output should be high and all other
should be low.
