Forum: FPGA, VHDL & Verilog Error: Coudl not Implement register on this clock edge
von Rex (Guest)
Hi all,
I want to reset the variable v_count to 0 at the rising-edge of input
port i_pulse_run. But I get the following errors:
Error: Could not Implement register on this clock edge. and
Error (10821): HDL error at PWM_Gen.vhd(85): can't infer register for
"CTRL:v_count[15]" because its behavior does not match any supported
register model.
How else can I reset the variable to 0. I want to reset it only at the
rising edge of signal i_pulse_run.
Any suggestions are welcomed.
Thanks
LIBRARY IEEE;
USE IEEE.numeric_std.all;
USE IEEE.std_logic_1164.all;
CTRL : PROCESS(i_Reset, i_Clock,i_pwm_pulse_run)
  variable v_PWMout        : std_logic;
  variable v_intPWMvalue    : integer range 0 to 8192;
  variable  v_updatePWMvalue  : std_logic;
  variable v_count : integer range 0 to 65535;
BEGIN
IF i_Reset = '0' THEN
    -- Asynchronous reset
    o_PWM        <= '0';
    s_PWMCounter     <= 0;
    v_updatePWMvalue  := '0';
  ELSIF rising_edge(i_Clock) THEN
    -- Increment the PWM counter
    IF s_PWMCounter < i_PWM_Freq_Div - 1 THEN
      s_PWMCounter   <= s_PWMCounter + 1;
    ELSE
      s_PWMCounter   <= 0;
      if rising_edge(i_pulse_run) then
      v_count := 0; -- Error
      end if;
30
      if i_pwm_pulse_en = '1' AND  v_count < i_pulse_count +1 THEN
31
         v_count := v_count + 1;
32
      END IF;
33
    END IF;
34
35
36
37
END IF;
38
END PROCESS CTRL;
In what hardware may have two different signals a rising edge at the
very same time?
And what kind of hardware device may be able to be triggered on two
clocks?
I don't know any. At least not insid any FPGA nowadays...
> port i_pulse_run.
Then you must sync in this asynchronous signal and implement a
edge-detection:
-- shift register for edge-detection
signal sr_pulse_run : std_logic_vector(1 downto 0) := "00";
-- sync in the "run pulse" with a shift register
sr_pulse_run <= sr_pulse_run(0) & i_pulse_run when rising_edge(i_Clock);
IF i_Reset = '0' THEN       ----<<<< That is usually not neccessary!
    o_PWM        <= '0';
    s_PWMCounter     <= 0;
    ELSE
      s_PWMCounter   <= 0;
      if sr_pulse_run="01" then     ---- rising edge on signal
      end if;
      END IF;
    END IF;
And tell me: why the heck do you use so many variables? Did you program
processors in the last time?
: Edited by Moderator
