Forum: FPGA, VHDL & Verilog Carry Look Ahead Adder showing U at last bit position in SUM
Author: Rohan Narkhede (Guest)
I am getting U at the last bit position of SUM when I add two 32 bit
numbers a and b by carry look ahead adder in VHDL.
my code is as follows:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity cla_nbits is
generic (N : integer := 32);
    Port ( a : in STD_LOGIC_VECTOR (N-1 downto 0);
           b : in STD_LOGIC_VECTOR (N-1 downto 0);
           cin : in STD_LOGIC;
           sum : out STD_LOGIC_VECTOR (N-1 downto 0);
           cout : out STD_LOGIC);
end cla_nbits;
architecture Behavioral of cla_nbits is
signal g : STD_LOGIC_VECTOR (N-1 downto 0);
signal p : STD_LOGIC_VECTOR (N-1 downto 0);
signal c : STD_LOGIC_VECTOR (N-1 downto 0);
begin
g <= a and b;
p <= a xor b;
c(0) <= cin;
p1: process(p,g,c,cin)
begin
c(1) <= g(0) or (p(0) and cin);
for i in 1 to N-2 loop
    c(i+1) <= g(i) or (p(i) and c(i));
    end loop;
cout <= g(N-1) or (p(N-1) and c(N-1));
end process;
sum <= p xor c;
--sum(N-1 downto 0) <= p(N-1 downto 0) xor c(N-1 downto 0);
end Behavioral;
and the corresponding test bench i prepared is as follows:
library IEEE;
entity tb_cla_nbit is
--  Port ( );
end tb_cla_nbit;
architecture tb of tb_cla_nbit is
component cla_nbits
           cin : in STD_LOGIC;
end component;
signal at, bt : STD_LOGIC_VECTOR (31 downto 0) := (others => '0');
signal cint : STD_LOGIC := '0';
signal sumt : STD_LOGIC_VECTOR (31 downto 0);
signal coutt : STD_LOGIC;
begin
uut1: cla_nbits port map (a=>at, b=>bt, cin=>cint, sum=>sumt, cout=>coutt);
p1: process
begin
at <= X"FFFFFFFF";
bt <= X"00000001";
wait for 50 ns;
at <= X"FFFFFFFF";
bt <= X"00000000";
cint <= '1';
wait for 50 ns;
at <= X"1A7E34B5";
bt <= X"11111111";
cint <= '1';
wait for 50 ns;
end process;
end tb;
Please let me know how to see the LSB bit in the SUM.
: Edited by Moderator
Author: Duke Scarring (Guest)
1 useful
You need to drive the signal from one process only:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity cla_nbits is
    port (a    : in  std_logic_vector (N-1 downto 0);
          b    : in  std_logic_vector (N-1 downto 0);
          cin  : in  std_logic;
          sum  : out std_logic_vector (N-1 downto 0);
          cout : out std_logic);
end cla_nbits;
    signal g : std_logic_vector (N-1 downto 0);
    signal p : std_logic_vector (N-1 downto 0);
    signal c : std_logic_vector (N-1 downto 0);
begin
    g    <= a and b;
    p    <= a xor b;
    p1 : process(p, g, c, cin)
    begin
        c(0) <= cin;  -- not usable for the same signal outside the process
        end loop;
    end process;
    sum <= p xor c;
end Behavioral;
> _____________________________________________________________________
Pls do not use that stylish line, but instead the [ vhdl ] tags as shown
a few lines above each edit box:
    [vhdl]VHDL code[/vhdl]
Author: Rohan Narkhede (Company: student) (rohan_n)
Thank you so much Duke Scarring. This really works!
  • [vhdl]VHDL code[/vhdl]
